cost to set timing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA »</TD></TR><TR><TD CLASS="quote">call some shops man</TD></TR></TABLE>i called the dealer they want 90 an hour to look at it. if it is the timing then its a minimum 3 hour job. i was posting here to see if anyone knew it because they had to do it. i think calling shops is the obvious. my whole point in posting was to see if anyone can tell me without me calling shops and getting a run-around from them.
is it the timming with the gun you are talking about
or
checking if the timming points are correct crank and cam gears...
if you are talking about the adjusting just the timming
a digital gun will cost you under $80...
is pretty simple hook it up place the clip in the tester plug
and point move distributor as necessary..
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjride1020 »</TD></TR><TR><TD CLASS="quote">Just fired up my swap and the idle is really rough.... U guys think my timing is off?</TD></TR></TABLE>
sounds possible...
sounds possible...
noob question, is timing just timing. For ex. is the distributor for timing the spark, and cam gears for adjusting the cam timing, can you do both, like i always here to go + 2degrees, is that with the cam gears, distributor, or both. Some one give me a lesson on timing please! thanks a lot
thread jacking.....
fire sequence is off.....
thread jacking.....
