93 gsr rear disc setup, will it work on a 97cx hatch???
Old Apr 8, 2004 | 08:56 AM
92eg6's Avatar
Default 93 gsr rear disc setup, will it work on a 97cx hatch???
would i be able to swap the rear discs from a 93 gsr teg, onto my 97 cx hatch?
would it be worth it to swap all 4 disc's, or just the rear?
Old Apr 8, 2004 | 10:06 AM
hawjboi's Avatar
Default Re: 93 gsr rear disc setup, will it work on a 97cx hatch??? (92eg6)
If you have all four do all four...i have stock civic in the front and 93 gsr rear disc brakes in the back...they work perfectly fine..but don't forget the most important thing...the master cylinder or else it won't be worth it.
Old Apr 8, 2004 | 10:25 AM
92eg6's Avatar
Default Re: 93 gsr rear disc setup, will it work on a 97cx hatch??? (hawjboi)
i can baisically get any parts off of the 93 gsr because my friend just totaled his, so i just wanna know if the rear will fit and if the front would be worth all the work, my civic ones are cross drilled and slotted already, and all four are cross drilled on the gsr
93JDMEGG
Sep 7, 2009 07:54 PM
dadsvtechonda
May 3, 2007 05:35 PM
celph.
18
Dec 7, 2003 09:01 PM
ron
Jul 10, 2002 05:21 PM
