gsr not starting anymore.
Old Apr 8, 2004 | 08:09 AM
GSRcivicGSR's Avatar
Default gsr not starting anymore.
my car used to start fine. i took off my dist. let me friend try it out on his car. his car ran fine. then when i put it back on my car it wouldnt start. i was thinking maybe it could be the cap and rotor. someone else was telling me it could be timing. how could timing be affected when i take off my dist? anyone can give help as to why its not working..
thanks/
Old Apr 8, 2004 | 08:10 AM
Team 4R's Avatar
Default Re: gsr not starting anymore. (GSRcivicGSR)
you may have put the distributor in "backwards"......... as in it is pointing to the number 4 spark plug wire instead of the number 1 wire at tdc......
Old Apr 9, 2004 | 10:03 AM
Default Re: gsr not starting anymore. (Team 4R)
well its on the right way. checked for spark and it had it. checked for fuel and it got it too. when i try to start it it turns over but it sounds funny. ive heard my cr turn over without starting and it almost sounds different. anyone else could help me out? thanks.
Old Apr 9, 2004 | 10:04 AM
The King's Avatar
firing order off ??
Old Apr 9, 2004 | 10:08 AM
RTE117's Avatar
So.. Did you flip it 180 to see?
Old Apr 9, 2004 | 10:13 AM
Default Re: gsr not starting anymore. (IDriveAHonda)
i did flip it 180 degrees. still nothing. firing order is correct too.
Old Apr 9, 2004 | 10:51 AM
Gadget's Avatar
FIrst check to see if you have power to the fuel pump and ecu.. turn your key on and listen to see if you can hear your fuel pump running for about 2 seconds while your check engine light is on.. if that checks out, see if you are getting fuel pressure. (you can loosen the nut on top of your fuel filter bolt, do not remove, fuel should spray from around the bolt.) if that checks out, you should remove your cam cover and check your cam timing to make sure your timing belt is tight and that it did not jump a notch or two on the belt..
Old Apr 10, 2004 | 08:57 AM
Default Re: (Gadget)
the fuel pump is working. i took off the valve cover today. i noticed that the "up" notches on my stock cam gears are not at the same postion. like when one of them is pointed straight up. the other "up" is almost down. i suppose this means it jumped teeth. anyone know how i can fix this up.
Old Apr 10, 2004 | 10:48 AM
kreush33's Avatar
Default Re: (GSRcivicGSR)
Dont go by the "up" they are just general reference go by the side markings on the cam gears. I know that when mine is timed right the "up" on one cam gear is slightly cocked to one side. Basically the "up" is there so you dont time your car 180 degrees off. line up the two side marks on the cam gears and make sure they are level with the head. If all you did was take out your dis, and put it back in i would make sure that its not 180 off which it sounds like you already did
Old Apr 10, 2004 | 07:10 PM
hatchi's Avatar
if its cranking chances are its the firing order have you double, triple checked that?? otherwise check the fuses
Tommy818
28
Oct 22, 2012 10:00 AM
prelude2.2
Apr 24, 2012 12:23 AM
platinum_rich
15
Feb 25, 2012 08:16 PM
xiztence
Nov 29, 2008 02:33 PM
ek-g6
Oct 9, 2007 01:29 PM
