Using a ABS Master Cylinder without ABS?
Old Apr 8, 2004 | 06:36 AM
CharmCity's Avatar
Default Using a ABS Master Cylinder without ABS?
I just converted my 94 SI to non-abs. I bought a non-abs master only to find out it doesn't bolt on to the abs brake booster. Now one of the holes on my abs master is larger then the connector on the non-abs brake line. What I was going to do is cut off the connector that goes into that hole, and cut off the smaller connector on the non-abs line, reflair it and put the larger connector on. I see no problems with doing this, however, is using the larger abs MC going to cause me any problems? I figure wince my motor is out, it would be easier to change out the brake booster now if that's what I need to do. Thanks!
Rob
dustinbs144
Nov 10, 2010 05:27 PM
Ohio
Sep 29, 2010 11:30 AM
sh4mr0ck
Jul 23, 2009 07:21 AM
Chim Chim
Mar 31, 2007 07:36 AM
zCivic
May 4, 2004 05:49 PM
