Wow cheap what to look for?
I am getting a b18b1 99 motor from a shop by my house. For a 1000 dollars full swap minus the ecu that seems really cheap to me. The motor is out of the car so I am wondering what are some things I can look at to see if it is a good motor, or what to look out for to see if it is a piece of ****.
Modified by b18bme at 2:27 PM 4/8/2004
Doing a leak down is about the only thing I can really think of that would be an effective test, unless the shop has an engine dyno and will hook it up on that for you. Most shops dont have a way to run an engine outside of a car, so there cant really be a true compression test.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">Do a compression test, and a leak down test.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA »</TD></TR><TR><TD CLASS="quote">make sure its not stolen too</TD></TR></TABLE>
How can I do a compression test if it is out of the car? I was wondering things like maybe check the spark plugs to see how they have been worn out, maybe look at the cams and see the coloration. **** I dont even know. How do I find out if it is stolen?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bme »</TD></TR><TR><TD CLASS="quote">How can I do a compression test if it is out of the car?</TD></TR></TABLE>
As long as you can turn the crank, you can do a compression and leakdown test.
superslow-oto
Jul 16, 2008 05:00 PM
