What tire size for 7x15" wheels? (Track use only)
As it says I'm gonna be shopping some track tires for my ITR, and have a set of 7x15" wheels i plan to use. What would be the best tire size on these wheels?
I am thinking of getting a set of Bridgestone Potenza RE540 in either 205/50 or 215/50, the 215 ones are actually a bit cheaper. I know these are not available in the US but they are quite popular here in Europe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99ITR#3715 »</TD></TR><TR><TD CLASS="quote">Yes they are about 1lbs lighter than the 215's</TD></TR></TABLE>
which is equlivant to around 25lbs of static mass in your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond »</TD></TR><TR><TD CLASS="quote">which is equlivant to around 25lbs of static mass in your car.
1lb of rotational mass = 25 lbs static mass? wtf?
Can you back that up with some hard data?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">1lb of rotational mass = 25 lbs static mass? wtf?
Can you back that up with some hard data?</TD></TR></TABLE>
1lb/tire * 4 tires = 4lbs of rotational mass.
The general rule I believe is 1lb of rotation mass = 6lbs of static mass.
Hence 4lbs * 6 = 24lbs
I may be wrong though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond »</TD></TR><TR><TD CLASS="quote">The general rule I believe is 1lb of rotation mass = 6lbs of static mass.</TD></TR></TABLE>
From where?
Either way, you shouldnt sacrifice grip for marginal improvements in power or weight.
From where?
From where?
Either way, you shouldnt sacrifice grip for marginal improvements in power or weight.</TD></TR></TABLE>
And on that note, 225/45/15's on 15x7" wheels here.
From where?
From where?
So you think I should go for 215/50 instead of 205's?
From where?
ehmm.. i woud'nt go any wider than 205's for 15x7..
and for these saying about rotational mass, you will never see a difference.. its all in theory and stays there.. just like lighter flywheel.
you cant do that.
rotational inertia factors in the radius of the rotation. That being said, the actual radius matters.
now if your assuming everyones going to use a wheel/tiresize that is "oem"
then your comparison might be right.
you cant do that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99ITR#3715 »</TD></TR><TR><TD CLASS="quote">As it says I'm gonna be shopping some track tires for my ITR, and have a set of 7x15" wheels i plan to use. What would be the best tire size on these wheels?</TD></TR></TABLE>
The most common size on that wheel is 205-50-15, by an overwhelming margin.
Remember that "R" compound tyres are wider than the "205" would normally lead you to believe, however.
What offset are your wheels? If they're in the 35-38 range, you might actually have to think carefully about the fit on the outside, especially, for some reason, the left rear.
215 is also a good choice, and the racers are preferring 225-45-15 R compounds these days, but there can be fender fitment problems with some wheel/tyre combinations. :D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^jefs0nq »</TD></TR><TR><TD CLASS="quote">I read that name 5-6 times and I still.. don't.. believe..</TD></TR></TABLE>i agree..... WTF Hmmm ghost or LiAR?.. haha
