96 Ex Build, What to do next
Old Apr 7, 2004 | 09:19 PM
icer350's Avatar
Default 96 Ex Build, What to do next
I have 96 motor that is at the machine shop right now being over bored .02 and sleved. The head is also there being ported and polished. I have new JE pistons that are going in the engine raising the comp. 10.5:1. I also have a Fidanaza(sp) Flywheel. I am also going to purchase a zex cam to replace the stock one. I already have under drive pulleys, cam gear, Cold air intake, header, straight pipe, and cat back exhaust.
I have been on the site reading for about a month, but havent found any useful information dealing with my car. If anybody has any usefull information on what to do next that would be great. I am not looking for any forced induction yet, I had a turbo for a little while, but wasnt working out.
Also one other thing, how much power can the stock rods and crank hold. I haven't been able to find any info on this either, cause I am going to use the stock at the moment unless there ****.
Adam
96 Civic Ex
Cold Air, Header, straight pipe, Cat Back
Aem Cam gear and Under Drive Pulley's
Motor being rebuilt with better parts
Old Apr 7, 2004 | 10:45 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: 96 Ex Build, What to do next (icer350)
well, if you really want to see a nice power gain, get boost, but hold up, you just said that your not looking for any type of forced induction...
my .02
Old Apr 8, 2004 | 01:33 PM
icer350's Avatar
bump
Old Apr 8, 2004 | 01:42 PM
BauleyCivic's Avatar
Risky Business
Default Re: (icer350)
Personally I would've done the 86-87 pistons for a little more compression...10.5 is fairly low. I'd then upgrade the valvetrain (springs, retainers) and get a wild cam (eg exospeed SOHC VTEC stg 3)...then after that get hondata s100 or 200 and get that bitch tuned.
Old Apr 8, 2004 | 01:44 PM
Xander teh Grate!'s Avatar
Default Re: (BauleyCivic)
I hope you got cash, NA powerhouse civics will cost you. Especially the single slammer.
Old Apr 8, 2004 | 08:11 PM
icer350's Avatar
I have read about the s100 and s200, they require me to change to obd1 correct. How hard it to install? And Does it run ok?
Also, If 10:5 is low, how high would a turbo kit add to the compression, I was thinking of geting the edelbrock Turbo kit.
TNight
10
Apr 3, 2015 08:00 AM
97civicdx
Apr 27, 2006 04:58 AM
u5711
Jan 22, 2004 01:07 PM
MikeMAN
Oct 7, 2002 08:07 AM
