Timing belt replacement.
Old Oct 26, 2001 | 11:42 AM
kickdown's Avatar
Default Timing belt replacement.
I have a question for those that have succesfully done both. Is there any drastic differences in belt replacement on a b18b and b18c? I have assisted on a b18c before, but now I own a 93 1.8l ls integra..
Also, where can I get the repair manuals that dealerships use..?
kickdown
[Modified by kickdown, 8:46 PM 10/26/2001]
[Modified by kickdown, 10:01 PM 10/26/2001]
[Modified by kickdown, 12:02 AM 10/27/2001]
Old Oct 26, 2001 | 01:01 PM
kickdown's Avatar
Default Re: Timing belt replacement. (kickdown)
bump.
Old Oct 26, 2001 | 01:15 PM
KL's Avatar
KL
New User
You will need a deep socket (can't remember the size) to remove the nuts on the drivers' side engine mount, make sure you have one so you don't find out after you've taken half the car apart then have to put it all together to drive to PepBoys or something, don't ask me how I found out on my 90GS.
Otherwise it is pretty much the same as my 96GSR.
The most important thing is to get someone with an impact wrench to loosen the crankshaft pully bolt for you ahead of time and HAND TIGHTEN the bolt on. Guess how I found this out.
I happen to have a 92 manual that is clean and effectively un-used, I bought it to read up more about VTEC GSR, make me an offer. I am in Toronto, Canada though.
Old Oct 26, 2001 | 02:26 PM
C-speed's Avatar
Default Re: Timing belt replacement. (KL)
Check here to see details on how its done:
http://www.c-speedracing.com/howto.html
Old Oct 26, 2001 | 03:05 PM
kickdown's Avatar
Allright, sounds good. I figured it was mostly the same. Also, when I did it I had a mechanical lift and all the right tools (ex honda mechanic) - how much of a pain in the *** will this be with jackstands and a floor jack?
kickdown.
musikpal
Aug 28, 2009 01:41 PM
slipperyduck
Jun 11, 2004 10:07 PM
Jaybird20
Jun 7, 2004 08:37 AM
RacerZook
Jan 6, 2004 12:06 PM
HondaHonda
Oct 28, 2001 09:08 PM
