'99 Honda CRV antenna problem
Hello,
My friend has a '99 CRV and her radio was having a problem being fuzzy and stuff. I checked and her antenna was not coming out when she turned on the car, so I pulled it out and it did not pull back in when the car was shut off, so either the motor is bad or just has bad connections, from what I'm told. I'm told the motor is in the fender. I'll have to check again since I just found this out but I'm pretty sure the motor is not coming on and trying to work, so the mast itself is OK. Where would I locate the motor in the fender, or wiring leading up to it? Can I fix/replace this easily or does it require taking the fender off (or maybe the inner fender)? Thanks for any and all help!
Is this the antenna that is on the roof above the drivers door? If it is, that one is not motorized, you have to manually pull it out/push it in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccerguy045 »</TD></TR><TR><TD CLASS="quote">Actually, I lied/was misinformed, it's a 2001 model. But yes, it's the one on the roof. Same deal with it being manual?</TD></TR></TABLE>
Yes.
Yes.
