Pully install questions
Old Oct 26, 2001 | 10:37 AM
smokin rubber's Avatar
Default Pully install questions
I picked up a set of aem pullys today and will be putting them in on sunday. How long should the install take? are there any special tools necessary I looked over the instructions and haynes manual breifly and will be reading more after work. Any tips would be great.
Old Oct 26, 2001 | 10:48 AM
urbanlegend21's Avatar
New User
Default Re: Pully install questions (smokin rubber)
i thought it was pretty cut and dry, remember the nut on the power steering pulley is threaded backwards
SOHCArchangel's Avatar
alternator pulley is a pain, and the not on the ps pump is counter thread, i dont reccomend the alternator pulley if you have had your battery relocated, and have some current demand like a system, cloaking device etc....
Old Oct 26, 2001 | 11:26 AM
New User
Default Re: Pully install questions (SOHCkordVTEC)
it is easier if you just remove your whole altenator, and yeah I also don't recommend using them if you have an electronic demand for your car.
Old Oct 26, 2001 | 08:06 PM
Default Re: Pully install questions (urbanlegend21)
thanks for the info, This should take a couple hours max then?
0ni
Jun 26, 2005 02:01 PM
aznteg
Jun 7, 2005 01:26 PM
Draggin99Si
Aug 28, 2004 06:02 PM
B00ST2nR
Oct 8, 2003 04:55 AM
01itr518
Dec 29, 2001 02:40 PM
