Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Making my own rollcage... have you done it before?
Old Apr 7, 2004 | 04:41 PM
boostedcivichatchbacksi's Avatar
Default Making my own rollcage... have you done it before?
if i make my own 4 or 6 point rollcage, will it be able to pass inspection? I'm lookin to save a buck and i have a 220 mig welder, so can anyone give me some opinions on this. thanks
Old Apr 7, 2004 | 04:43 PM
.RJ's Avatar
.RJ
Default Re: Making my own rollcage... have you done it before? (boostedcivichatchbacksi)
What inspection are you trying to pass?
Unless you really know what you are doing....... or have someone there that does, I would not do it. You may need that cage to save your life.
Old Apr 7, 2004 | 04:53 PM
Default Re: Making my own rollcage... have you done it before? (.RJ)
er rollbar, not cage
Old Apr 7, 2004 | 04:57 PM
FormulaIntegra's Avatar
Same response. If you're asking cuz you don't know....don't.
Old Apr 7, 2004 | 05:06 PM
civicrr's Avatar
Default Re: Making my own rollcage... have you done it before? (FormulaIntegra)
A 220 Mig welder will have more than sufficient power to weld the .120 wall tubing needed. (Assuming the car is a Civic or 'teg) How are you as a welder? Be honest with yourself. As stated above, your life can depend on it. Do you have a tubing bender? I am talking about one designed for this type of work. A 'regular' bender will end up crimping the tubes. Do you have a tubing notcher? It takes a lot of time & practice to get nice tight fit ups. This is definitely an instance where you won't want to do any 'filling in' with the welds (not that you should ever be if you have any pride in your work).
A better thing to do is to offer to help an experience cage builder. You might not save any money, but you will gain a wealth of experience.
Old Apr 7, 2004 | 05:08 PM
Default Re: Making my own rollcage... have you done it before? (civicrr)
HM I GUESS i'll just buy an autopower bar and add points to it.
Old Apr 7, 2004 | 05:14 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivichatchbacksi &raquo;</TD></TR><TR><TD CLASS="quote">and add points to it.</TD></TR></TABLE>
Add what points?
What for?
Old Apr 7, 2004 | 05:25 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Add what points?
What for?</TD></TR></TABLE>
buy a 4 pt race roll bar and maybe have a custom front welded onto perhaps
Old Apr 7, 2004 | 06:05 PM
tnord's Avatar
Default Re: Making my own rollcage... have you done it before? (Emerika)
it takes more than just a welder to be able to build a rollbar/cage ya know.
you'll need to make bends as well as notch pipe. do you have the equipment to do that? how much experience welding do you have? the strength and quality of those welds is what keeps you alive.
i watched a man die in a racing incident this weekend, cages are not something to fug around with. have a professional do it. trying to save a few bucks, how much is your life worth to you?
Old Apr 7, 2004 | 08:13 PM
ITACivic's Avatar
Pay someone.
Old Apr 7, 2004 | 08:21 PM
k279's Avatar
I have a friend who builds rally car cages help me , or i helped him in building my cage in other words . Its definately not a "bend it and weld it" type of thing. I would get help or buy it.
Old Apr 7, 2004 | 08:50 PM
GBRacing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivichatchbacksi &raquo;</TD></TR><TR><TD CLASS="quote">I'm lookin to save a buck</TD></TR></TABLE>
This is the wrong thing to say when talking about a safety item.
Old Apr 7, 2004 | 10:02 PM
TeamSlowdotOrg's Avatar
Default Re: Making my own rollcage... have you done it before? (ITACRX)
Every buck saved on safety is one hundred bucks extra spent at the hospital after a crash!
You like supporting your local hospital right? Sweet, you're all set.
Old Apr 8, 2004 | 06:05 AM
r2x's Avatar
r2x
Pass whose inspection? That matters.
Go buy/get the rulebook for whatever sanctioning body you want to run with and read it. Then, read it again. Then start to plan your cage. Then, read it again. Then start building.
miscmotorsports
Welding / Fabrication
Feb 14, 2010 12:53 PM
kelsodeez
Northern California
14
Sep 19, 2009 02:43 PM
Ding
17
May 9, 2006 01:52 PM
jmad08
Feb 25, 2002 08:09 PM
