transmission rebuild tool
Does anyone have a slide hammer bearing puller to pull the bearings out of the clutch housing side of the tranny case (input and counter shaft bearings). If so, where'd you get it? How much?
Any other techniques that will work w/o the slide hammer?
Thanks,
Ken
Thanks,
Ken
I had to order the adjustable bearing puller b/c I couldn't find a puller small enough to squeeze into the ID of the bearing. It's about $72.00.
You can rent a slide hammer from Autozone.
Maybe Dan knows a better way to do it.
TravisBiggie
Honda Civic (2001 - 2005)
Nov 25, 2012 02:00 PM
Wes V
22
Oct 25, 2003 12:51 PM
