Apexi Power FC Idle Problems.
Hi,
My friend has just got a used power Fc from a board member.
This was tuned on his itr which is very identical in mod specification to my friends itr, so we thought it should plug and play with maps already there and let her rip............................No way.
We plugged in the power fc and the idling is erratic, it fluctuates between 400-1100 rpm all the time and when we try to rev it, a the cel comes on.
Help guys as in Malta there is no one capable of tuning a Power Fc.
This power Fc was tuned by XS engineering, what do you think guys?
Thanking you,
Thanking you,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTwinz »</TD></TR><TR><TD CLASS="quote">There's a voltage you have to enable or disable I forgot. I had the same prob before until I kept on messing around with the sensor screen.</TD></TR></TABLE>
Is it in the setting screen on enable and disable ****??? i think i have been messing with the FC commander and im throwing a CEL for no reason..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteec »</TD></TR><TR><TD CLASS="quote">Hi,
https://honda-tech.com/zerothread?id=1290602
When your CEL is up, does your can runs like this? im in need of infos too...
and does it solved?
and does it solved?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus »</TD></TR><TR><TD CLASS="quote">You did the self learning idle adjustment after installing it? The procedure is clearly stated in the manual.</TD></TR></TABLE>
the manuel is in Japanese,, which i cant read...plus, tuner tune my car right after i have no idea whats have to do with the ecu..
Ok i try to download a manuel in English and let see what i can do...sigh
my stoopid car...
my stoopid car...
