Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Are these SBC Camber Adjustments Quality Stuff for Track Days??
Old Apr 7, 2004 | 01:18 PM
pcorad's Avatar
Default Are these SBC Camber Adjustments Quality Stuff for Track Days??
I'm looking at some camber correction products. Is this a quality product? Race proven?
http://www.spcperformance.com/....html
I don't want to snap a ball joint in Turn 6 at Watkins Glen.
Old Apr 7, 2004 | 02:38 PM
jc836's Avatar
Default Re: Are these SBC Camber Adjustments Quality Stuff for Track Days?? (pcorad)
If you are talking about the Specialty Products kits shown-they work very well. SPC is one of the oldest manufacturers of alignment products. They do extensive R&D on each design. Our race car and the Prelude have this company represented. The Prelude uses the 67135 and since install they have virtually no wear from both road or HPDE. The race car uses SPC eccentric anchor bolts (required) and they are holding up well thus far. If you want to see the quality of their stuff-I'll be at The Glen mid July (PDA). Let me assure you that you will not have a problem with the parts when properly installed and aligned. This has been my experience. The Bus Stop can be interesting depending on your entry speed as can the boots corners. Race Safe
Old Apr 7, 2004 | 04:26 PM
pcorad's Avatar
Default Re: Are these SBC Camber Adjustments Quality Stuff for Track Days?? (jc836)
Thanks for the feedback. I've run with PDA for years - have we met? I'm purchasing a new house in 2 weeks, which may keep me away from the track a bit. We'll see. Are you doing any other North East events in the near future?
I've been tracking a very stock 97 ITR for years. It currently has Koni yellows and stock springs. I'm likely to go the coil over route sometime in the future, but I'd like the ability right now to adjust camber on a stock set up. Swapping tires on rims to prolong their life gets tedious.
Thanks again.
Old Apr 7, 2004 | 04:52 PM
Austin's Avatar
Here's a post that I made about a new version that SPC will be coming to market with shortly:
https://honda-tech.com/zerothread?id=820846
Austin
Old Apr 14, 2004 | 10:09 AM
h22mark's Avatar
Default Re: Are these SBC Camber Adjustments Quality Stuff for Track Days?? (Austin)
After reading that, many people seem to have a problem with the ball joint camber kit, is there a problem with these will they slip? I have them now but have not installed them, should I have gotten the anchor bolts?
Old Apr 14, 2004 | 01:04 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc836 &raquo;</TD></TR><TR><TD CLASS="quote">The race car uses SPC eccentric anchor bolts (required) and they are holding up well thus far. </TD></TR></TABLE>
Do you have a part number for those too? I'm sure I would use the same ones.
rasmussen00
Jan 21, 2011 04:26 PM
EJK20R
Suspension & Brakes
Mar 20, 2006 10:37 PM
jda90
Suspension & Brakes
Aug 19, 2005 10:33 AM
SpecR_EK
Feb 26, 2002 01:15 PM
