clutch lost pressure today... help??
Old Oct 26, 2001 | 08:55 AM
Bklyn TSi's Avatar
Banned
Default clutch lost pressure today... help??
This morning when i got up for a drive to class, i found out the engaging point of my clutch was unbelievably low! the first 3/4 of it had no pressure whatsoever... everything was fine yesterday... could it still be the clutch wearing out? or am i needing oil or anything? help pls...
Old Oct 26, 2001 | 01:34 PM
976's Avatar
976
New User
Default Re: clutch lost pressure today... help?? (Stony TSi)
Check fluid - uses brake fluid - some are not all compatible. Check for leaks in master and slave cylinders. Bleed them (hydrolic) of oxygen.
Old Oct 26, 2001 | 03:55 PM
Bklyn TSi's Avatar
Banned
Default Re: clutch lost pressure today... help?? (B21A)
weird part is, i took the car for a good 3 hour drive (had to head back to NYC then back here in LI), the clutch pressure went back up to normal for like a good hour, and then came flat again... checked fluid, added it to the max, still no change.... is it master cylinder? or new clutch time?
[Modified by Stony TSi, 10:41 PM 10/26/2001]
Old Oct 26, 2001 | 07:01 PM
fixhondas's Avatar
sounds like it is time for a clutch master and slave.
Old Oct 29, 2001 | 02:29 PM
Bklyn TSi's Avatar
Banned
Default Re: clutch lost pressure today... help?? (fixhondas)
anyone has any different opinions? i really don't think its the master cylinder.. the perssure came back up to normal today.. could it be a hose or pump (is there a clutch pump)? the pressure dropped and came back up twice already... so weird.
Old Oct 29, 2001 | 02:36 PM
976's Avatar
976
New User
When there is air in the lines, or you master/slave is going - it will do that, gain pressure, stay for awhile, then drop agian. It's the oxygen flowing though the lines. There is no pump, well, the master and slave cylinders work like a pump. Are you losing fluid? Are your slave/master leaking? Check...
Old Oct 29, 2001 | 02:37 PM
DR. ON POINT's Avatar
Banned
try and bleed the system and get out all the air
Old Oct 29, 2001 | 04:55 PM
fixhondas's Avatar
Default Re: clutch lost pressure today... help?? (On Point)
weather can change pedal feel in a situation like yours. I just worked on an integra today that needed a master and slave- friday it had some pedal, enough to shift gears, but today when I pulled it in the shop it had no pedal.
[Modified by fixhondas, 8:56 PM 10/29/2001]
Old Oct 29, 2001 | 05:09 PM
fixhondas's Avatar
Default Re: clutch lost pressure today... help?? (rawdigga)
it was a 94 ls- the reservoir was empty and the the pedal was stuck to the floor. If you replace the master you should replace the slave as well- 99% of the time the slave goes shortly after the master. Lack of fluid changes causes this.
EddieLe76
Jan 14, 2010 01:50 PM
fcjohnny
Nov 19, 2009 07:33 PM
eg6sittingon57cs
Aug 8, 2007 10:44 AM
4LugR
May 5, 2005 10:07 PM
SlowPoke
Nov 25, 2002 09:36 AM
