Diagram of H22 harness
Old Apr 7, 2004 | 07:25 AM
1hotcivicSi's Avatar
Default Diagram of H22 harness
I JUS RECENTLY DID A H23 TO H22 VTEC SWAP IN MY LUDE I AM USING MY H23 HARNESS.. DOES ANYONE HAVE THE LAYOUT OF THE WIRES FOR THE VTEC HARNESS SO I CAN WIRE EVERYTHING IN THAT I NEED FOR VTEC
Old Apr 7, 2004 | 07:29 AM
Sam1am26's Avatar
Default Re: DIAGRAM OF H22 VTEC WIRING HARNESS (1hotcivicSi)
https://honda-tech.com/zerothread?id=818727
that is assuming you have a 93+ prelude
Old Apr 7, 2004 | 12:46 PM
Greyout's Avatar
Default Re: DIAGRAM OF H22 VTEC WIRING HARNESS (Sam1am26)
what if its a '92? Do you just to run a wire from the ECU, or replace the under-hood harness?
Old Apr 7, 2004 | 12:59 PM
Sam1am26's Avatar
Default Re: DIAGRAM OF H22 VTEC WIRING HARNESS (Greyout)
you have to run the wires directly to the ECU, you can find ecu pin outs by serching...
Old Jun 24, 2010 | 06:19 PM
tazh22a's Avatar
i bought a 92 prelude and it has a jdm h22A, and i have been searching and cant find a definate answer, can i run the wire from the solenoid straight to the ECU and im good to go cuz from the looks of it the pressure switch is wired? help please.
harvster87
Jul 11, 2009 06:22 PM
Lude-venom
Nov 5, 2008 07:18 PM
boosted_teg93
Oct 24, 2004 06:54 PM
shadowludeJDM
Mar 29, 2004 09:07 AM
