Cant hook........Help me with avc-r tuning.....
Well, I just got my slicks yesterday and went to the track. 23" slicks on my 89 civic hatch with b16 stock bottom end, stock head, 3mm headgasket, and block guard. t3/t40e turbo and quaife lsd. I cant seem to cut a good 60ft. Now my best time was 12.8@121 with a 2.24 60ft on slicks! Man that sucks
121 is good for much lower. That was on the last run when I actually was able to heat them up good which kinda bogged it off the line when I dumped it at ~4000rpm which was spinning them the previous three runs. I need to drop at say 6000? Once boost built in first it broke them free again and I had to shift to second. I have an avc-r boost controller and have 1st turned down all the way -50%. Base boost is set at .7 with 35% duty. 1st -50%, 2nd -20%, 3rd +50%, 4th +50% now I want to be able to bring 1st down more and 3rd and 4th up more but 50%+/- is the furthest it will let you go. With these slicks being brand new, will they start to hook up better after a few runs??? I know I need to learn how to drive it better. This is the first time at the track with this car and first time Ive run on slicks, so spare the comment.
This was my time slip.
rt .499
60' 2.241
330 5.941
1/8 8.692
mph 90.02
1000 10.989
1/4 12.871
mph 121.27
121 is good for much lower. That was on the last run when I actually was able to heat them up good which kinda bogged it off the line when I dumped it at ~4000rpm which was spinning them the previous three runs. I need to drop at say 6000? Once boost built in first it broke them free again and I had to shift to second. I have an avc-r boost controller and have 1st turned down all the way -50%. Base boost is set at .7 with 35% duty. 1st -50%, 2nd -20%, 3rd +50%, 4th +50% now I want to be able to bring 1st down more and 3rd and 4th up more but 50%+/- is the furthest it will let you go. With these slicks being brand new, will they start to hook up better after a few runs??? I know I need to learn how to drive it better. This is the first time at the track with this car and first time Ive run on slicks, so spare the comment.This was my time slip.
rt .499
60' 2.241
330 5.941
1/8 8.692
mph 90.02
1000 10.989
1/4 12.871
mph 121.27
