headgasket question
Old Oct 26, 2001 | 06:41 AM
zdr262's Avatar
Default headgasket question
i have a question and i was wondering what the diffrence between the b16a and the b18c head gasket and will a b16a one fit on a b18c or is the b18c have bigger bore size than the b16. the only reason i was wondering is because i have a honda dealership about 1 block away from my house and they have one in stock, the nearest acura dealership is about 45 miles away and has to order one and it usually takes those bf's about 3 weeks to get one and i need one today that is why i was wondering about the alternitives... i didnt think it would work but its worth a try any information would be much appreciated
Old Oct 26, 2001 | 06:44 AM
FSTASNTZ's Avatar
Default Re: headgasket question (zdr262)
The B16A and B18C have the same head gasket. Same bore and same oil and coolant passages.
Jason
Old Oct 26, 2001 | 08:03 AM
zdr262's Avatar
Default Re: headgasket question (FSTASNTZ)
thanks for the info i do appreciate it
Old Oct 27, 2001 | 12:38 PM
type autox's Avatar
New User
Hey do you know the diffrences between the vtec headgasket and the ls gaskets?
Old Oct 27, 2001 | 12:58 PM
zdr262's Avatar
Default Re: headgasket question (type autox)
yea the ls headgasket and vtec basically very diffrent head gasket. for example the dowl pins are located on the oppisite side of the block from the b18b and the b18c also oil passages are diffrent the ls headgasket doesnt have a hole for the oil passage on the vtec head and it has these copper rings on the ls that are in diffrent places on the b18c headgasket. water passage lines are pretty much the same that is about it.
Old Oct 27, 2001 | 01:06 PM
zdr262's Avatar
also if you want more or a example check this out it is my best explination is in pictures of the diffrences http://www.geocities.com/thelsvtec/ls_vtechowto.html
check this out has the diffrences and a copy of how i built mine gives good info on the diffrences
[Modified by zdr262, 10:16 PM 10/27/2001]
eg6madness
Nov 1, 2007 11:33 AM
gezzuzz
May 24, 2007 11:32 AM
HondaMan73
Jul 30, 2004 01:05 PM
HondaMan73
Jul 30, 2004 12:18 PM
tommyblaze
Nov 29, 2003 07:28 AM
