The strength of bondo?
Old Apr 6, 2004 | 06:53 PM
Eluzion's Avatar
Default The strength of bondo?
I am considering picking up an Integra pretty soon but the problem is, the current owner shaved the side moldings, antenna, and emblems using bondo. If I remember correctly, the antenna hole is pretty damn big but the side molding and emblem holes aren't too big. He used bondo to shave it and his friend "used something on the back to support it". Well, I'm not going to count on whatever was used to "support it". Is bondo strong enough to hold its own or would it eventually start cracking or cave in?
Thanks!
Old Apr 6, 2004 | 07:15 PM
Full Race A6's Avatar
Default Re: The strength of bondo? (Eluzion)
I used bondo as well to shave my side mouldings, if he just layerred bondo in there like the 3/4" then I wouldnt buy it. But I spot welded a very thin peiece of sheet metal acrooss and about 1/8" of bondo to make it smooth.
I also did the antenna and rear wiper, all held up great. Im sure itll eventually crack but none so far and it looks great for cheap
Old Apr 6, 2004 | 07:21 PM
xdjoynerx's Avatar
bonda is good for like emblem holes.......... not filling in moldings. i wouldnt buy it.
Old Apr 6, 2004 | 07:24 PM
Eluzion's Avatar
Default Re: (xdjoynerx)
Well on the Integra side moldings... you just pull them off and fill in the holes, no? They're not like Civics with a huge indent.
Thanks for the replies!
Old Apr 7, 2004 | 12:18 AM
xdjoynerx's Avatar
id be too scared for it to crack
thats just me though.
Old Apr 7, 2004 | 05:20 AM
I dont know how big the indent is but I know bondo is strong
Old Apr 7, 2004 | 06:05 AM
Erik95LS's Avatar
Default Re: (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">I dont know how big the indent is but I know bondo is strong
Since when?
Old Apr 7, 2004 | 07:10 AM
Default Re: (Erik95LS)
got proof that it isnt?
Old Apr 7, 2004 | 07:22 AM
Eluzion's Avatar
Well, there is no indent. It's just holes that were filled with bondo. The only one I'm really worried about is the antenna hole since that one is pretty big.
Old Apr 7, 2004 | 07:27 AM
Default Re: (Eluzion)
Im sure that there would be some kind of backing if it was a big hole because when you apply bondo is a soft past and you cant just cover a hole becuase it drops down, there has to be some sort of backing.
I used very thin sheet metal or a layer of fiberglass before filling any holes at all
Old Apr 7, 2004 | 07:57 AM
Eluzion's Avatar
Default Re: (W O T)
Yeah, I'm sure there's something backing it but the question is, what is it? The guy said his friend did it... maybe it was sheet metal spot welded? *shrug* I'm going to go take a look at it today.
Thanks for the replies.
JLopezDC2
Paint and Body
May 17, 2011 02:09 PM
LOLYOUMAD
Welding / Fabrication
Jan 16, 2011 07:29 AM
HI91EFHB
Aug 21, 2009 02:04 PM
R Legend
Nov 12, 2008 01:14 PM
mrchaos
Jun 27, 2004 02:11 PM
