'99 H22 Prelude Turbo Problem
Old Apr 6, 2004 | 04:49 PM
chris2k's Avatar
Default '99 H22 Prelude Turbo Problem
My bro and I just installed a turbo on our '99 Prelude and we're having problems with the map sensor seeing boost. We installed the "missing link" but according to the VTEC controller when the pressure in the manifold goes positive (at about 5-6psi) the engine begins to hesitate.
Here's what we've done. We've installed the missing link with open side down and the side with the small pin hole facing up. We then put the MAP sensor on top of that. My question is that there is an open port (nozzle) on the front side of the missing link. Should this be connected to anything (check valves or left wide open) or should this hole be plugged up?
We've also got a set of adjustable cams on the car. Should we reset these to 0 degrees / 0 degrees? I believe it's currently set to +2 degrees / 0 degrees. Any help would be greatly appreciated!
-Chris
myst0ryman
Mar 27, 2006 06:38 PM
00preludesipoop
May 5, 2005 01:24 PM
_VTI-R_
Feb 26, 2003 01:12 PM
1fstevo
Sep 19, 2002 06:04 PM
ludelvr
May 31, 2002 06:20 PM
