ported F23 intake manifold---pics inside
sup guys, look what i've done at work!
when i took the intake manifold apart, i was disappointed, ours aren't like the F22 where the inside of the plenum is one big chamber, we kinda have a pocket inside there, soo it looks like this isn't going to extrude hone. but anyways, i decided to open up the begining of the runners inside the plenum sinced they looked like crap. i sharpened all the walls to try and create the least turbulance. i also started on the throttle body, but it doesn't look good, i damaged my TPS sensor when dropping the engine out of the car, and since the TPS is permanently attached to the throttle body, i had second thoughts, but the switch still works, its just the connector cant stay connected since the clip is busted, duno, maybe i'll try it just to see how good i can get it, then maybe do the one on my car. i thought about opening up the end of the runners, but things are pretty good there, i'm just gonna port match the head to the intake manifold and not touch the intake manifold any more. i wont be touching my engine any time soon, if any of u are, and would like to buy my intake manifold then hit me up.
this is before, i just started a lil, for got to get a whole picture of everything.
this is after. i just sharpened the edges going in and blended them in 2-2 1/2inches.
the head is next! more pics to come!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyrojeff »</TD></TR><TR><TD CLASS="quote">You should polish it too!
What did you use to widen the holes? A dremel?</TD></TR></TABLE>
good job~
head over to accordinglydone.com/forum... they would love to see this.. a few f23 guys there
good job~
a
up for you
but you might want to do a little more practices
P&P job done by my professor
[IMG][http://www.imagestation.com/picture/...15634.jpg/IMG]
up for youbut you might want to do a little more practices
by no means am i a pro....but the head is next. i'm gonna open it up to the gasket, looks like ur professor went bonzai on that V8 head, but i think the V8 heads aren't as good from the factory as the hondas are.
sloweh3
12
Oct 22, 2007 09:29 AM
krott5333
May 6, 2004 11:09 AM
g_man80
Aug 15, 2002 10:57 AM
