Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
what do i launch @ with slicks
Old Oct 25, 2001 | 11:00 PM
I-VTECRX's Avatar
Default what do i launch @ with slicks
90 TEG w/b16 itr valve springs,ctr cam,ctr piston.25, itr manifold,6puck clutch HD PP can anyone enlighten me!!!
Old Oct 26, 2001 | 03:52 AM
maxQ's Avatar
Default Re: what do i launch @ with slicks (EF8hYbRid)
You might try asking this as well in the EF forum or the Hybrid forum...
Andy - who MUST resist....
Old Oct 26, 2001 | 04:50 AM
Crack Monkey's Avatar
You launch as high as you can without excessive wheel spin. You'll just have to experiment. My guess would be 4000-5000rpm, but lacking a LSD might need a lower launch.
Old Oct 27, 2001 | 08:44 AM
BryanSprinkel's Avatar
You want to launch pretty high on slicks. Try around 7k or as close to redline as possible.
Bryan
Old Oct 28, 2001 | 01:07 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: what do i launch @ with slicks (VAtypeR00)
first warm them up with a second gear burnout. Then launch at 6k+ rpm
Also remember tire pressure will rise the most after the first burnout. I start at 11-12 psi before first burnout and check pressures to 13-14 just before hitting the burnout box.
Must be doing somthing right, 1.87 60 ft's for a juiced SOHC Civic.
13.55 @ 100 mph with full interior this time!
Old Oct 28, 2001 | 07:37 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Re: what do i launch @ with slicks (Mista Bone)
for the burnout just drop the hammer in 2nd gear? which rpm to drop the hammer? higher the better? i'm a bit weary to do slicks next time after my snapped axle on street tires couple of weeks ago.
Old Oct 28, 2001 | 02:20 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: what do i launch @ with slicks (frank@b16a.com)
Set Ebrake.
I rev the motor to about 3000 and let the clutch out while feeding more gas. Bring rpms up to about 6000-6500 and hold. When the slicks get sticky they will drag the back tires through the water box.
Do 1 dryhop to make sure tires are dry and stage.
Old Oct 29, 2001 | 07:27 AM
NegativeLift's Avatar
Default Re: what do i launch @ with slicks (maxQ)
What do you have to resist, Andy? This IS the competition forum , isn't it?
Old Oct 29, 2001 | 07:49 AM
maxQ's Avatar
Default Re: what do i launch @ with slicks (NegativeLift)
nOthInG rEAllY, mR. weIGhT. nEvER mINd.
Old Oct 29, 2001 | 08:28 AM
Muckman's Avatar
Moderator in Chief
What the HELL is that? A snapped axle?
holly crap.. wouldnt u think something in the tranny would go before an axle? Thats about an 1" - 1.5" of pure steel!!
hey your fingures are a little cut up! hah been working on your car too long.
Old Oct 30, 2001 | 07:19 AM
thats better
Old Oct 30, 2001 | 07:29 AM
maxQ's Avatar
KMA, T.
BTW, the F-15 was going supersonic vertically 20 years ago.
[Modified by maxQ, 12:01 PM 10/30/2001]
Old Oct 30, 2001 | 02:46 PM
KMA, T.
first, i shall not like to kiss your ***.
second, im not an aeronautics expert, maybe you are- regardless, this is the wrong thread in which to be correcting me. If you would like to comment on my opinion of the Su-35 please place it in the appropriate topic; dont tuck it away where I'm not looking. I don't mind being corrected; I welcome it. Thank you.
third, and with respect, why is it that you had to "resist" to a question about legal drag racing? If you don't like the question, don' t post. You don't have to like drag racing, but you should respect it. Here is the quote under the Competition Forum listing:
Discussion of modifications, tuning, and driving techniques autocross, road racing, and drag racing
notice the last two words. If you don't like it, complain to the moderators and perhaps they'll create a "Cone Racing Geek"* category for you.
*This comment should be taken with the levity and humor for which it was intended. I enjoy autocrossing as well as many other forms of racing. I know maxQ's attitude does not represent the majority of auto-xers and road racers on this board.
Old Oct 30, 2001 | 03:36 PM
maxQ's Avatar
Arrgh... Out of respect for the "majority of auto-xers and road racers on this board", I'm not going to get into this with you here.
However, I would like you to realize that your virulent behavior is based upon an incorrect assumption on your part... AT NO TIME, have I tried or suggested to discredit legal drag racing and my suggestion to ask elsewhere as well in my original post was given in sincerity for the large number of reputable drag racers in those forums as well.
Andy
Old Oct 30, 2001 | 10:34 PM
Mista Bone's Avatar
D Tranny Guru
Frank hurt his axles by doing a burnout with MAJOR wheel hop and failed to stop.
THIS is why his axle snapped.
smokestreetrace
16
Dec 18, 2010 12:26 AM
jsw_1986
May 1, 2009 03:19 AM
LSVTEC 91 Civic
14
Apr 22, 2005 03:57 PM
98cwitr
Mar 14, 2004 12:49 PM
B_CRUZ!
Aug 5, 2002 05:57 AM
