Stuck Tranny......
Old Oct 25, 2001 | 10:17 PM
Turbohatch's Avatar
New User
Default Stuck Tranny......
today i started out on a fairly simple project, removing my tranny. As i was removing the last bolts for the upper tranny i relized that my tranny was still in thier pretty good. I removed the last bolts and hoisted the engine for support. The tranny is not coming out so i overlooked ever spot on the tranny where the chilltons says there is a bolt, there all out. my shift linkage is out why isn't it coming. I removed my friends ls and it was cake why is mine such a bitch........
it is a Ls tranny on a b16a
[Modified by Turbohatch, 7:18 AM 10/26/2001]
Old Oct 26, 2001 | 12:41 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Stuck Tranny...... (Turbohatch)
Did you the starter bolts and the bolt in back?
There is one bolt that goes through the motor and threads into the tranny case. It is close to where the rear bracket mounts to the tranny.
Old Oct 26, 2001 | 10:51 AM
Turbohatch's Avatar
New User
Default Re: Stuck Tranny...... (Mista Bone)
does anyone know how many mount bolts i have to take out in total
Old Oct 26, 2001 | 12:25 PM
JDMspecEG's Avatar
New User
There is three for the front lower mount on the tranny casing plus the two that bolt to the chassis underneath. On the upper passenger side mount there is two nuts and one bolt plus the one that holds the mount to the chassis. On the rear just take out the two ones that bolt into the tranny. Have fun gettin the tranny off!
GSR_hatch936
Feb 2, 2008 04:34 PM
EK FLY
Feb 18, 2005 03:29 PM
cincispeedemon
Oct 10, 2004 02:50 PM
cr-x si
16
Jun 19, 2003 09:13 PM
spladam02
Dec 8, 2002 06:42 PM
