Tire Size Question
Old Oct 25, 2001 | 08:58 PM
GSR18's Avatar
Default Tire Size Question
I'm about to get some new tires for my 16" wheels with a +40mm offset. I was wondering what is the correct wheel size so there would be no rubbing. 215/45/16 or 205/45/16? What would you recommend? What are the pro's and con's? Thanks.
Old Oct 25, 2001 | 09:18 PM
degradated's Avatar
New User
Default Re: Tire Size Question (GSR18)
205/45/16 is the correct size. Theoretically, you could run the wider size, but the overall tire diameter would be farther off from your stock diameter, leading to a more inaccurate reading on your speedometer.
The 215mm tire also has a greater chance of rubbing for obvious reasons, especially at a +40 offset.
Old Oct 25, 2001 | 09:21 PM
degradated's Avatar
New User
Default Re: Tire Size Question (degradated)
also...the wider tire will tend to be a couple pounds heavier per tire, if you are concerned with weight. I spent prime $$ on superlight wheels, so I made sure to also choose a tire that is light weight (Toyo T1-S)... The same tire in the 215 size was 2 pounds heaver per corner, I believe.
DA9Sleeper
Jan 26, 2010 01:29 AM
Nbboy7
Apr 12, 2008 05:38 PM
yaryar
Jan 10, 2008 07:11 AM
bboixtc
Apr 3, 2007 07:44 AM
enzozenuni
Jan 29, 2007 10:53 AM
