Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
does anyone make +2mm wheel spacers, searched
Old Apr 6, 2004 | 10:45 AM
teal_dx's Avatar
Default does anyone make +2mm wheel spacers, searched
I am looking for 4x100 +2mm spacers, I have searched and someone said H&R made them but the smallest they have is +5mm. +3mm is the smallest I can find anywhere but i really need +2mm for my rims.... is there +2mm spacers out there?
thanks
Old Apr 6, 2004 | 10:47 AM
tnord's Avatar
Default Re: does anyone make +2mm wheel spacers, searched (teal_dx)
you could probably have a machine shop make them, they're not complicated devices.
Old Apr 6, 2004 | 10:48 AM
SPiFF's Avatar
http://www.opmautosports.com/
Old Apr 6, 2004 | 11:43 AM
teal_dx's Avatar
Default Re: does anyone make +2mm wheel spacers, searched (SPiFF)
checked the link... couldnt find anything about spacers in their products. did i miss it?
Old Apr 6, 2004 | 12:33 PM
Greyout's Avatar
what do you need to fix with 2mm that makes 3mm overkill?
Old Apr 6, 2004 | 02:19 PM
teal_dx's Avatar
Default Re: does anyone make +2mm wheel spacers, searched (Greyout)
ok long story...
I have 4 16x7 40mm rims w/ 205/45/16 tires. 1 rim is bent (beyond repair). The rims are out of production, i have searched all over. I found 2 somewhat similar rims, 16x7 42mm but not exactly the same. It would not be that noticible that 2 of the rims are different from the original 2 as long as they are on the opposite side of the car. so that means i would have the +40mm ones on the driver side and the +42mm ones on the passenger side because the two +40mm are the same style and the two +42mm are the other style. So I need (2) +2mm spacers for the +42mm rims so the car will not pull to one side. Right now the smallest I can find is +3mm which will work if I use +3mm spacers on the +40mm side and +5mm on the +42mm side but then that will put me at +37mm at all 4 corners which will rub very bad. So If I can find a pair of +2mm spacers then I will be set
If +2mm spacers are this hard to find what do you think about just buying a pair of +3m spacers and having a machine shop take of 1mm... or is that easoer said than done?
Old Apr 6, 2004 | 02:24 PM
jisu009's Avatar
just buy new wheels
Old Apr 6, 2004 | 02:26 PM
Greyout's Avatar
heh - interesting plan. Are they very unique wheels? 4 16" rotas can be had for $500 or so
Old Apr 6, 2004 | 02:35 PM
teal_dx's Avatar
they are ADR lightning, kinda rare but not expensive when they were new. there are almost identical styles made by other companies but no smaller than 17"
I would love a new set of rotas but i'm stuck on the $500... id rather buy a pair of used rims for <$100. my banged up rusty hatch isnt worthy of new rims and I dont have to worry about any theives ripping off my 2 mismatched pairs of rims
I care more about handling than looks, and im cheap
Old Apr 6, 2004 | 05:15 PM
metalworker's Avatar
If you won't be able to tell that you have different wheels on each side, I don't believe you will be able to see 1 mm difference in offset. But anyway, we make the ones for OPM and I think we can help you. Im me or call tomorrow (wednesday) and I'll see what we can do.
Walt Puckett
Delta Group Motorsports
704 434 8046
Old Apr 6, 2004 | 06:10 PM
Jake's Avatar
Default Re: does anyone make +2mm wheel spacers, searched (metalworker)
If you care more about handling than looks and you're cheap, then just put one set in back, and the other up front.
Another option is to turn the 40mm offset rims into 42mm offset rims by having a machine shop shave 2mm (really not that much) off the mating surface.
Old Apr 6, 2004 | 07:49 PM
CRX Lee's Avatar
Default Re: does anyone make +2mm wheel spacers, searched (Jake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jake &raquo;</TD></TR><TR><TD CLASS="quote">If you care more about handling than looks and you're cheap, then just put one set in back, and the other up front.
.</TD></TR></TABLE>
If Walt can't set something up for you, I'd put the 40mm offset on the front and the 42s on the rear. In fact, if you check your car stats, there is a good likelihood that your front and rear track width aren't the same front and rear anyway. Put the 40s on the narrower end. I don't think you'll ever see 2mm of offset and the car will still be symmetical.
cf5412
Honda CR-V & Element
Nov 10, 2016 03:00 PM
low_and_slow
Apr 25, 2010 08:51 AM
strtracedrmr
Honda Civic (2001 - 2005)
Sep 9, 2007 05:33 PM
Guiding my way back.
Jan 24, 2007 03:35 PM
EMphaticONE
Jan 22, 2005 05:38 PM
