is this possible for an oil cooler
Old Apr 6, 2004 | 09:55 AM
jdmcx's Avatar
Default is this possible for an oil cooler
i was wondering if this set up would work
if i take a braided line form the back of the block (oil pressure sensor) to and inlet of an oil cooler and from the outlet of the oil cooler to the oil pan
please let me know thanks
jason
Old Apr 6, 2004 | 11:20 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: is this possible for an oil cooler (jdmcx)
no, use a sandwitch adaptor to feed the oil to the cooler.
stan
Old Apr 6, 2004 | 04:50 PM
jdmcx's Avatar
Default Re: is this possible for an oil cooler (Stan D)
why wouldn't it work
Old Apr 6, 2004 | 05:36 PM
you want to feed your engine cooled oil, if used properly, by interrupting the flow of the oil between the oil filter and the block and redirecting it to the cooler you are feeding all the oil to the cooler and to the block, where in the case of feeding the cooler partial flow from the sender location you not only impede the flow as the sender orifice is much smaller than the oil filter orifice, but also mixing the cooled oil with the hot, used oil in the pan.
incidentally a proper way to feed the turbo with oil is similar to the cooler routing.
stan
Old Apr 7, 2004 | 06:38 AM
jdmcx's Avatar
ok now i see thanks
mrlegoman
Aug 4, 2009 10:03 AM
Touge Tuning
May 2, 2008 05:27 AM
Touge Tuning
Feb 9, 2007 11:24 AM
IVANITR
Nov 30, 2001 01:05 AM
