Replacing synchros and gears ?
Old Apr 6, 2004 | 08:30 AM
GhostInTheShell's Avatar
Default Replacing synchros and gears ?
i have a 92 accord lx with a lil grind into 3rd. i was hoping that i could replace the synchro on it before selling it but i don't know how hard it will be. i've been searching online and using hanes and chiltons manuals to get an idea, but they don't seem to say much about level of difficulty haha. i also want to buy a prelude but the second gear synchro is bad and i'm assuming that the gear is shot. if you have any idea about any of this give me some suggestions or a "how-to" online somewhere, thanks
Old Apr 13, 2004 | 07:17 AM
Default Re: Replacing synchros and gears ?
noooooooooooooobody knows anything?
Old Apr 13, 2004 | 01:16 PM
ben95ex's Avatar
Default Re: Replacing synchros and gears ? (GhostInTheShell)
get yourself a helms shop manual, and a good assortment of tools.
i've torn down and rebuilt a ford muncie 4speed before, pretty straightforward. if you are decently mechanically inclined and do things slowly and carefully you'll do fine.
make sure to check the wear on the dog teeth, since worn synchros will put more stress on them, and you might end up replacing the whole gear if you have to.
it's not like rebuilding an engine as far as difficulty, but there are plenty of tiny little things that are easily lost like snaprings and such. take your time and get a helms.
Old Apr 14, 2004 | 05:43 AM
Default Re: Replacing synchros and gears ? (ben95ex)
Thanks, good info. I've torn apart ford C-4's before and it wasn't bad at all. This is just a little bit different though and i'm hoping that i won't mess anything up. I'll have to see what happens
Old Apr 15, 2004 | 06:20 AM
gooberwolf's Avatar
it is probably better to just replace the tranny unit. I think 2.2L trannies are interchangeable between accords and preludes and they are pretty cheap on ebay. Trannies replace should cost 400-500-max (parts and labor). Synchros could be close to a tranny rebuild in terms of costs.
F22dreams
Sep 29, 2007 11:31 AM
Turbochargedcivic
10
Aug 15, 2006 11:56 PM
JinteDgraM
Mar 22, 2005 01:51 PM
cr-x si
Apr 14, 2003 08:34 PM
zijiejijeijrkjk
Jul 30, 2002 04:15 PM
