Rear Speaker Wiring Question
Old Apr 6, 2004 | 05:09 AM
downsmith's Avatar
Default Rear Speaker Wiring Question
Can someone tell me on a 1997 Accord, what is the polarity of the rear speaker wires?
Old Apr 6, 2004 | 05:13 AM
SearchBeforeUPost!'s Avatar
Default Re: Rear Speaker Wiring Question (downsmith)
sure dOOd, positive and negative
Old Apr 6, 2004 | 07:13 AM
1994AccordSiR's Avatar
::shakes head
but to answer your question the polarity is blue green red and yellow
Old Apr 6, 2004 | 01:04 PM
downsmith's Avatar
OMG!!!
Here are your choices:
Left side has a blue wire with a yellow stripe and a green wire with a white stripe.
Right side has a red wire with a yellow stripe and a blue wire with a white stripe.
Being a college graduate (Class of 1989) I figure that the yellow stripe means + and the white stripe means -.
If this is not correct, please let me know.
Smart-*** replies, although generally funny, are of no use to anyone and waste storage space and bandwidth.
Old Apr 6, 2004 | 02:13 PM
under advisement's Avatar
Default Re: (downsmith)
The white striped wires should indeed be the negative side.
Old Apr 6, 2004 | 02:18 PM
ask a dumb *** question, get a dumb *** answer.
Your assumption is correct. Yellow striped wires are positive; white striped wires are negitive.
Old Apr 9, 2004 | 09:16 AM
Heat's Avatar
Default Re: (SearchBeforeUPost!)
Well, there's your answer.
I did run across this if you ever are not sure if your speakers are correct on other cars:
To check speaker polarity (assuming you don't have a polarity tester): Touch, for a very short period of time, one wire to the positive side of a 1.5-volt battery (any size), and the other wire to the negative side. If speaker "pops out", then polarity is correct. If speaker "pops in" then polarity is reversed. Make sure that the wires you are going to check for speakers do not have any power.
Old Apr 9, 2004 | 10:43 AM
Beach Accord's Avatar
Default Re: (Heat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heat &raquo;</TD></TR><TR><TD CLASS="quote">Well, there's your answer.
To check speaker polarity (assuming you don't have a polarity tester): Touch, for a very short period of time, one wire to the positive side of a 1.5-volt battery (any size), and the other wire to the negative side. If speaker "pops out", then polarity is correct. If speaker "pops in" then polarity is reversed. Make sure that the wires you are going to check for speakers do not have any power. </TD></TR></TABLE>
or you can just use a freakin digital volt\ohm meter
Dredakid05
Audio / Security / Video
Mar 28, 2009 12:07 PM
denshu
Lighting
Nov 8, 2007 08:02 AM
hondaon18's
Jul 28, 2007 11:34 AM
