Cam gear settings
Old Apr 6, 2004 | 03:47 AM
DanishR's Avatar
Default Cam gear settings
I am going to have my car tuned tomorrow. A set of RS Machines cams has been installed. The internals are stock(Euro-R). Does anyone know how much the cam gears can be adjusted safely?
Old Apr 6, 2004 | 02:30 PM
DanishR's Avatar
Default Re: Cam gear settings (DanishR)
Anyone?...
Old Apr 6, 2004 | 03:33 PM
Willard's Avatar
I have not (and I am not sure if anybody in the US has) heard of 'RS Machines' cams.
Does the cam maker have any info that would help you?
Old Apr 6, 2004 | 05:00 PM
B2FiNiTY's Avatar
Default Re: Cam gear settings (Willard)
I've heard of those cams here on honda-tech but haven't seen much info on them.
The best and for sure way is to get on a dyno if there is one around you. Otherwise I wouldn't even install the cams.
Old Apr 6, 2004 | 07:55 PM
gamby's Avatar
It's a given that you'll need to do this on a dyno, but...
Advancing or retarding up to 4 degrees is pretty safe. 5 degrees gets sketchy, but usally do-able. Don't adjust much further than this--you might get some interference.
Old Apr 6, 2004 | 07:56 PM
Padawan's Avatar
Darth ModerVader
The only way to know for sure would be claying, and since that probably isn't a viable option for you at this stage, I'd stick to something conservative like +/- 5 degrees. I doubt you'd have to venture much outside that range to see maximum power anyway.
Old Apr 6, 2004 | 10:37 PM
DanishR's Avatar
Default Re: Cam gear settings (Padawan)
Thanks.
I'll tell them to keep it conservative.
I know it has to be tuned. They were installed yesterday, and I am going to the dyno today.
I'll post some results later.
IMPATIENT
Sep 18, 2007 03:50 AM
JDAMC
Mar 8, 2007 05:14 AM
anthony90si
Sep 28, 2006 08:34 PM
blowme
Jul 5, 2005 05:23 PM
Redsun
Aug 30, 2004 06:23 AM
