exhaust question
Old Apr 5, 2004 | 09:43 PM
nver2's Avatar
Default exhaust question
I got the cheese lame BW rear for my car. Now It wont fit cause my greddy evo is in the way. Is it safe to relocate the hangers and move the exhaust over a little? Like move the hangers near the tip just a few inches. Would that be possible without bending the catback or my header? Cause Im not to sure about it. I know this will get me Flamed but someone will know. Or have been in this same situation.
Old Apr 6, 2004 | 04:22 AM
RUBZERK's Avatar
Default Re: exhaust question (nver2)
Go for it
Old Apr 6, 2004 | 05:15 AM
SearchBeforeUPost!'s Avatar
Default Re: exhaust question (RUBZERK)
yes, you can do it. There is enough play in the system to relocate it a few inches.
Old Apr 6, 2004 | 05:35 AM
nver2's Avatar
Default Re: exhaust question (SearchBeforeUPost!)
thanks
Old Apr 6, 2004 | 06:07 AM
swift535's Avatar
i had the same problem, just cut & weld the hangars until its where you want it, no biggie just takes some time and doesn't hurt to have someone help you eyeball it
Old Apr 7, 2004 | 11:28 AM
nver2's Avatar
Default Re: (swift535)
is it ok to bend the hangers on the Evo exhaust at the end of it? Is that what you were talking about? Because I cant get it on still there is something in the way. That goes to the frame I will post up pics later tonight? Unless you guys know what Im talking about.
Old Apr 7, 2004 | 04:11 PM
nver2's Avatar
Default Re: (nver2)
see it needs to over more to the right but that piece with the gold on it of the frame or whatever is in the way. When I try to move it over the hanger cant go over anymore
Old Apr 7, 2004 | 05:42 PM
FatJoe's Avatar
Default Re: (nver2)
id say ditch the BW bumper if you have too many problems and run into a dead end you could always go to a welding shop and let them know what you need and they will do it for you no problem. good luck
Old Apr 7, 2004 | 05:45 PM
swift535's Avatar
yeah i had mine done at the shop, on the low end i'd guess $30 high end $60 for a job like that
Old Apr 7, 2004 | 06:24 PM
nver2's Avatar
thanks guys
Old Apr 7, 2004 | 07:50 PM
Mike813's Avatar
Default Re: (nver2)
i got the bw rear bumper on also when i got the car... for looks its pretty decent. but it is one PITA if you have lots of potholes in your area... i took a damn sander and sanded down practically most the rear due to bottoming out constantly... im in ny home of the potholes ;\
but from what it looks like u can always get longer hangers welded that shouldnt cost too much..
Old Apr 7, 2004 | 09:08 PM
Riceburner247's Avatar
Default Re: (Mike813)
Post more pics of your ride.
Old Apr 14, 2004 | 12:00 PM
nver2's Avatar
Default Re: (riceburner247)
Ok so I took my car to a exhaust shop on last Sat. It was a bitch because i had to put my bumper in the trunk. Well after cracking it a little bit from the ride. I get to the shop and they say it will be 20 mins before they can look at it. So then I walk to mcdonalds and come back at about 20 mins. They say look there is no way the bumper and this exhaust will work im sorry. So i tell them my friend has the same car same exaust and same bumper. They say well it must have hung lower on his car. I said well do what u have to do. They said it wont work we have certified technicians so after driving one hr to get there I had to put it in the trunk and take it back. I know it has to work what about MIDAS? So MAD HATTER EXHAUST screw you. It was such a bitch man that was hard work and for nothing. There the ones that told me to bring it to them and they would look at it. I guess that it was just because it was Easter Sunday the next day. So they wanted to go home and sex up there wifes.
Old Apr 15, 2004 | 08:13 PM
swift535's Avatar
i found asked around on local forums about where to get work like that done... you might want to do the same or chances are you'll get screwed. a lot of places aren't import-friendly anymore
Old Apr 15, 2004 | 08:52 PM
1illAccord's Avatar
Default Re: (nver2)
should work just fine.
Old Apr 16, 2004 | 04:03 AM
cleanaccord1997's Avatar
If i were u i would take offf your exhaust put on the bumper and then remake the exhaust and hangers to fit the new bumper
Old Apr 16, 2004 | 06:52 AM
1Accord4u2nv's Avatar
you still got that drivers side door? and what year accords will it fit on to?
Old Apr 16, 2004 | 07:55 AM
nver2's Avatar
Default Re: exhaust question (cleanaccord1997)
sounds like a good idea cleanaccord and no but i do have the passenger side door. I guess it will fit 94-97 4 door
Old Apr 16, 2004 | 07:20 PM
Default Re: (nver2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nver2 &raquo;</TD></TR><TR><TD CLASS="quote">Ok so I took my car to a exhaust shop on last Sat. It was a bitch because i had to put my bumper in the trunk. .......... I guess that it was just because it was Easter Sunday the next day. So they wanted to go home and sex up there wifes.</TD></TR></TABLE>
lol.
silly question, but did you try to bend the hangers that are on the muffler?
Old Apr 16, 2004 | 07:36 PM
Mike813's Avatar
Default Re: (SearchBeforeUPost!)
like i said above, cant you just weld on new hangers??? that should be like a 15 min job...
and can your car even fit the bw rear?? looks super low already doesnt look like itll clear....
Old Apr 19, 2004 | 09:47 AM
nver2's Avatar
no i didnt i dont really want to do that. Its a expensive exhaust but that would work probably I have thought about it. But the hanger may never be the same on the exhaust. It should fit good cause the guy I bought the bumper from had the same car and exhaust and it was fine. He also had two inches of the bumper cut out and the fiberglass reinforced.
Old Apr 27, 2004 | 11:40 AM
nver2's Avatar
Default Re: (nver2)
So now I took it to another place and they said that they can make it fit. But they will have to cut the stainless steel hanger on the exhaust. They said they will also have to heat the exhaust up to move it over 3-4 inches is that safe? A guy at the shop also said we could get the exhaust and make it work. I said not that exhaust no way.
steveteggy92
Dec 5, 2007 11:10 AM
Jstans84
Honda Civic (2001 - 2005)
Jun 24, 2007 02:59 PM
Themouse
Dec 24, 2005 07:35 PM
HitEm'Up
Mar 25, 2005 11:25 PM
WhitEdRift
Mar 7, 2004 09:58 PM
