problems with ignition timing after distributer install...
Old Oct 25, 2001 | 05:19 PM
John's Avatar
New User
Default problems with ignition timing after distributer install...
I installed a replacement Hitachi distributer this evening on my F22B1... However, now my powerband is all screwey, no low end power whatsoever... I'm assuming its my ignition timing... so how do I set it back to the OEM ignition timing setting (aside from my cam timing setting)? do i have to use a timing gun? help!
Old Oct 25, 2001 | 05:57 PM
John's Avatar
New User
Default Re: problems with ignition timing after distributer install... (DunReit)
thanks for Honda318dx, I rectified the problem to a certain extent by loosing the distributer bolts and rotating it (the ignition timing was retarded too much)...
Old Oct 26, 2001 | 12:54 PM
Accord_Munch's Avatar
At least you can adjust your timing ... on my 97 I believe you can't change the timing.
eg grom
Jun 25, 2009 09:27 PM
mortificationrock
Jul 10, 2007 04:26 PM
John
Oct 25, 2001 10:49 PM
