install a cold air
Old Apr 5, 2004 | 06:41 PM
christina's Avatar
Default install a cold air
i have a 2004 honda civic and i'd like to know how to install a aem v2 cold air. but its a little different, you can still go on top, but i want to put it underneath, can anybody help me out.
Old Apr 5, 2004 | 08:30 PM
sxng9's Avatar
Default Re: install a cold air (christina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by christina &raquo;</TD></TR><TR><TD CLASS="quote">i have a 2004 honda civic and i'd like to know how to install a aem v2 cold air. but its a little different, you can still go on top, but i want to put it underneath, can anybody help me out.</TD></TR></TABLE>
underneath?? ...i'm not quite sure about what you're asking. why don't you install it according to the manufacturer's installation method. it was designed that way for more efficient air-flow and performance. you will run into other problems along the way if you modify the CAI pipe or modify/extend the CAI pipe to run underneath the engine.
i also have an AEM v2 CAI, but on a 2000 Civic. the CAI pipe runs along the side, where the stock air box used to be and installing the CAI is super easy and you should already have the installation manual when you bought the CAI, should you need any help along the way.
Old Apr 6, 2004 | 03:58 PM
christina's Avatar
Default Re: install a cold air (sxng9)
when you put in a cold air its right beside your hot engine. theres a way to make the pipe go down in front, but you have to move your battery and such. im needin to know how that would work.
Old Apr 6, 2004 | 05:22 PM
Kal's Avatar
Kal
v2 isn't a true cold air. the aem cai would go underneath the bumper.. it is like that in the preludes at least.
Old Apr 6, 2004 | 08:54 PM
FlaN.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by christina &raquo;</TD></TR><TR><TD CLASS="quote">when you put in a cold air its right beside your hot engine. theres a way to make the pipe go down in front, but you have to move your battery and such. im needin to know how that would work. </TD></TR></TABLE>
post pics and you'll get better responses. it should be installed the way it tells you to in the manual
Old Apr 6, 2004 | 08:57 PM
christina's Avatar
Default Re: install a cold air (FlaN.)
will do but im at work now, thanks for responding, and on 04 theres something that comes under the hood that most cars dont have it has to be taken out too.
grandam
Mar 27, 2007 08:42 PM
I Am White
Mar 7, 2007 04:09 PM
Wolfwood
Jul 27, 2005 04:02 AM
christina
Apr 5, 2004 06:40 PM
GSRacer2102
Jan 5, 2002 09:55 AM
