changing spark plugs
Old Oct 25, 2001 | 03:41 PM
Seedc2's Avatar
Default changing spark plugs
My car has about 66k and I dont know when the previous owner decided to change spark plugs. I decided that it would be a good idea to get some new ones because when I start the car up in the morning I feel some hesitation (sometimes). How can one tell if you need a change?
well if I decide to change, I gotta few questions:
I guess im looking to go with NGK's. Or is there a better alternative?
Do I have to change the plug wires along with the spark plugs?
Are NGK's pregapped? or is this done on your own?
Do I need to replace the distributor cap?
Old Oct 25, 2001 | 04:07 PM
Fooman's Avatar
Default Re: changing spark plugs (kendogg)
Spark plugs are very easy to change out. And no, you don't need to change the wires, just the plugs. For me, I stuck with the stock NGK plugs which are pre-gapped. Make sure wherever you buy yours, that they are pre-gapped or you will need to gap them yourself.
You'll also need a torque wrench to be sure that your plugs aren't too tight. You'll also need a spark plug socket and an extension for your socket wrench that will let you reach into the engine to get the plugs. Everything else is just screw-in and screw-out.
Old Oct 25, 2001 | 06:16 PM
inochi's Avatar
New User
denso iridium!! spark plugs....only way to go!
Old Oct 25, 2001 | 06:59 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: changing spark plugs (Fooman)
I don;t feel a troque wrench is all that necessary an expense. Tighten it until it is snug and then go about a 1/4 to 1/2 turn more and you should be fine. You may want to get some anti-seize compound and put it on the threads of the plugs so it'll make it easier to take out next time.
mrtrinh
Honda Civic (2001 - 2005)
Feb 19, 2008 05:37 PM
globy123
50
Jun 10, 2007 08:49 PM
Nocturnal
Mar 28, 2003 05:25 PM
jdmspoonitr
Nov 9, 2002 06:26 PM
nsx-Animal
Jul 30, 2002 04:22 AM
