installing spark plugs
Hi.. Does anyone knows any good DIY guides for installing spark plugs and what tools I need? Is it hard to do the job or should I take it to a mechanic shop and pay $30 to change them? I bought some NGK spark plugs..
Re: installing spark plugs (globy123)
damn who charged 30 to change out plugs?!?!
dont feel like typeing it but if you really, really dont know http://www.ehow.com/how_110_re....html
Re: installing spark plugs (DrZoidberg)
I'm just reading instructions at NGK website and it says "Thread Diameter=18 ø mm" and "Cast Iron Cylinder Head (lb-ft.)=25.3~32.5" .
http://www.ngksparkplugs.com/t...e=nml
What do they mean by thread diameter and cast iron cylinder head?
What tool would you use to measure the Thread Diameter and the Cast Iron Cylinder Head in lb-ft?
Here is another link:
http://autorepair.about.com/od...e.htm
I recommend you buy a gapping tool to check the spark plug gap, and adjust as necessary (I don't fully agree with that link regarding not having to check the gap. Better safe than sorry.)
Tips:
Do one spark plug at a time. Grasp the spark plug wire at the base of the rubber boot to pull out; you may have to wiggle it back and forth a little.
When putting in the new spark plug, just use the spark plug socket and extension without the rachet, and screw it in by hand first. Don't force anything, if it doesn't screw in easily, stop and take it back out and try again. You do not want to cross-thread it. After it is finger-tight, then use the rachet on the extension and socket, and turn it about a quarter turn. (You don't want it too tight or too loose.)
I like to put a small dab of di-electric grease on the inside of the spark plug wire boot, to help removal of the wire the next time around.
Tips:
you can even get them pre gaped. get a helmes manual, it will be your bible haha jk just dont pay 30 for this, if I was anywhere near you I would do it free of charge...best of luck to you
Ek Forever y0!
Re: (blackouthx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy »</TD></TR><TR><TD CLASS="quote">half an hour to install spark plugs
does that include his 29:45 minute lunch break...
Fixed
You're 23, and can't change out spark plugs on a honda.
Take out, replace.
It's not rocket science. There's a reason no one makes a write-up for it. Likely because my 8 year old cousin did the plug on my Dirtbike a while back.
Fixed
Take out, replace.
Re: (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">Just dont overtighten them. make sure they are snug</TD></TR></TABLE>
Ohh yea the best feeling in the world has got to be when someone stripps the threads for the spark plug holes.
Ek Forever y0!
Re: (Jhonny Ricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer »</TD></TR><TR><TD CLASS="quote">
Ohh yea the best feeling in the world has got to be when someone stripps the threads for the spark plug holes.</TD></TR></TABLE>
Re: (globy123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by globy123 »</TD></TR><TR><TD CLASS="quote">Do you know any good anti seize compounds to put on the spark plug threads?</TD></TR></TABLE>
the kind you get at the autoparts store
Ek Forever y0!
Re: (globy123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by globy123 »</TD></TR><TR><TD CLASS="quote">Any good brand names you recommend?</TD></TR></TABLE>
Anti-seize is anti-seize. There's not going to be any difference except in price.
I don't even use anti-seize on my spark plugs.
You can buy enough at the counter in a little tube labled "Anti-Seize" If you really care. it's about $ .50
Re: (globy123)
if you must have a name..
I use just about Permatex everything since its what my autoparts store stocks
Re: (sicones)
Sorry about the stupid questions I'm asking guys..I just want to do the job right. Another question I have is how long does the ratchet extension has to be to reach the spark plug?
Just make sure you gap them and do it yourself. Very easy, just have someone who knows what they are doing to help you and make sure you tightent them to specs.
Re: (ek forever guy)
Hey guys..So I managed to change the spark plugs and I took some pictures of the old ones. I know you can tell how the engine is running by looking at the spark plugs. Should I be concerned about anything????
http://img2.freeimagehosting.n...6.jpg
http://img2.freeimagehosting.n...2.jpg
http://img2.freeimagehosting.n...8.jpg
http://img2.freeimagehosting.n...f.jpg
Re: (globy123)
Are they gapped correctly?
You should be concerned about that.
EDIT:
Most people change the dizzy rotor, cap, and plug wires too when they do the spark plugs...
Might wanna do that too, I go w/ bosch wires, a lot of pple on H-T complain about them and will tell u to get NGK but I've always used bosch wires w/ NGK V-Power's on Hondas and I never had a problem.
Also, next time you buy plugs, buy the $4 NGK V-Power plugs from autozone/advance auto/pep boys - that's OEM and obviously a lot cheaper than you paid (30 > 16).
EDIT:
Re: (Syndacate)
Those are my old spark plugs. I bought the car about 2 years ago and I'm not sure when the previous owner changed spark plugs. I did put NGK V power spark plugs.
The new ones are gapped properly. The ones in the picture not sure if they're gapped properly but they are not being used anymore
Do you know any good torque wrenches that are accurate???
