Balancing Brake Rotors?
Old Apr 5, 2004 | 04:43 PM
benSC's Avatar
Default Balancing Brake Rotors?
I recently replaced both front rotors, and at the same time I also got a different set of wheels and tires(used). Now i have a vibration at about 60-65 mph. I've had the wheels rebalanced, but that didn't help. Has anyone gotten their rotors balanced? I've heard that the blanks you get for part stores aren't exactly true. Thanx in advance
Old Apr 5, 2004 | 04:47 PM
benSC's Avatar
Default Re: Balancing Brake Rotors? (benSC)
Forgot to ask where I could get this done. Thanx
Old Apr 5, 2004 | 05:07 PM
gumbii's Avatar
i've never seen that done before... i think you have some parrallelizm, or excessive run off... you probably have to get new rotors... get a micrometer and check for parrallelizm...
Old Apr 5, 2004 | 05:25 PM
benSC's Avatar
Default Re: (gumbii)
Could you explain that a little more. I don't really understand what that is.
Old Apr 5, 2004 | 05:48 PM
vtekstorm's Avatar
Default Re: (benSC)
balancing your rotors? i neva heard that in my life. now when u say u have a vibration at 65mph is this happening while your hitting the brakes. or is this vibration happening when your not hitting the brakes?
cuz if its happening while your cruising at 65 and yrou wheels are properly balanced. most likely u have a bent rim/rims, or u could have sum flat spots in the tries. since u bought them used i would look at the rims
thats just my opinion
Old Apr 5, 2004 | 05:55 PM
benSC's Avatar
Default Re: (vtekstorm)
I know the tires are pretty shitty, I'm about to replace them. I think I saw the brake balancing on that Horsepower TV or something. They described the exact situation that I was in: taking wheels to get balanced once or twice, and still having vibration. And god I hope my wheels aren't bent, that would SUCK!
Old Apr 5, 2004 | 07:07 PM
boostn420's Avatar
Default Re: (benSC)
There are some places that have a machine that balances the wheel on the car. It actually balances everything that is moving. Rotor, lugs and everything. Its expensive and if you take of the wheels its ruined.
Old Apr 6, 2004 | 02:45 PM
vtekstorm's Avatar
Default Re: (boostn420)
get sum newer tires and have them properly balances. or take 2 of your best tires u have on now and put them in the front . are your tires directionals? or just regular radials? cause wit radials you canswitch them crisscross but directionals can go only one way
AFAccord
Jun 24, 2005 05:02 AM
wilsel
Jul 6, 2004 04:57 AM
TIRENECK
Jan 27, 2004 03:12 PM
ITR #0202
Nov 17, 2002 08:50 AM
onyx00
Jan 11, 2002 05:58 PM
