Master Clutch Cylinder
easy, first siphen off as much brake fluid as you can. then unbolt brake lines first, then unbolt the MC, installation is opposite of removal.
add fluid, bleed MC, then all four brakes.
Actually I was looking for how to change the clutch master cylinder, because mines is leaking (slowly) from inside of the car, where it comes through the firewall.
Thanks
Thanks
ohh...hehe guess I should have asked first
never done that one, I suggest you pick up a haynes manual to help you along. should be the same exact process though.
Hard2Find
14
Aug 9, 2005 08:32 AM
lo0nY
12
Jan 28, 2004 02:15 PM
vtecdc2
May 20, 2003 07:27 AM
