Rattle when shifting
Old Apr 5, 2004 | 11:16 AM
.RJ's Avatar
.RJ
Default Rattle when shifting
I get an odd rattle when I engage/disengage the clutch. I can hear the rattle right at the top of the pedal travel - i.e. if i apply just a little pressure to the clutch I will start to hear it. It is more noticeable in 2nd/3rd/4th gear than 5th.
I had this video saved, not sure what it was from but the rattle you hear when shifting is identical to what I am hearing, although I think mine is louder. This is not my video
http://www.we-todd-did-racing....DE%3D (right click, save as).
Ideas? Throw Out bearing?
Thanks!
Old Apr 5, 2004 | 01:59 PM
Mugen Mike's Avatar
Default Re: Rattle when shifting (.RJ)
I couldn't make out a rattle in the video, but I had an odd rattle in my car a few weeks ago. I thought for sure it was the gearbox, but it turned out to be a missing header bracket bolt.
Old Apr 5, 2004 | 02:09 PM
B2FiNiTY's Avatar
Throwout bearing? Does it do it at idle?
Old Apr 5, 2004 | 02:28 PM
.RJ's Avatar
.RJ
Default Re: Rattle when shifting (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Throwout bearing? Does it do it at idle? </TD></TR></TABLE>
Nope
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">it turned out to be a missing header bracket bolt.</TD></TR></TABLE>
I'll check it oot
Old Apr 5, 2004 | 02:37 PM
B2FiNiTY's Avatar
Does it happen if your in N and just play with the pedal?
Old Apr 5, 2004 | 03:15 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Does it happen if your in N and just play with the pedal? </TD></TR></TABLE>
Yep.
I dont think its the header bracket, it was there before I installed the oil pan, and we tightened up the bracket.
Old Apr 5, 2004 | 03:17 PM
B2FiNiTY's Avatar
Since it also occurs in neutral, I would have to say that it is tranny/clutch related.
I was also guessing it could have to do with the shifter rods but since it happens in N, then that would eliminate it.
Has the problem been happening for quite sometime? Gets worse?
Old Apr 5, 2004 | 03:29 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I was also guessing it could have to do with the shifter rods but since it happens in N, then that would eliminate it. </TD></TR></TABLE>
I havent checked them out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Has the problem been happening for quite sometime? Gets worse? </TD></TR></TABLE>
It was present when I bought the car. I think its gotten a bit worse after 10 track days
Old Apr 6, 2004 | 04:22 AM
valentinecr's Avatar
New User
how many miles do you have on the clutch?
I think you might have the same problem i had, one of the springs in the pressure plate came loose and would rattle every time i shifted. You basiclly have to replace your clutch when that happens.
Old Apr 6, 2004 | 04:24 AM
Dan GSR's Avatar
couldn't hear **** in that vid
but your symtoms sound like it could be throw out bearing
is the sound rpm independant?
does the sound change with rpm?
sound go away when the clutch pedal is all the way down?
from what you've said so far, seem like its only making that sound in the top 1/4 of pedal travel, is this correct?
Old Apr 6, 2004 | 04:25 AM
.RJ's Avatar
.RJ
Default Re: Rattle when shifting (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">is the sound rpm independant?</TD></TR></TABLE>
Seems to get a tad louder at high rpm shifts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">sound go away when the clutch pedal is all the way down?</TD></TR></TABLE>
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">from what you've said so far, seem like its only making that sound in the top 1/4 of pedal travel, is this correct?</TD></TR></TABLE>
Yes
Old Apr 6, 2004 | 04:52 AM
DragII's Avatar
25 Year Member
definately seems clutch related. I'd check your heat shields, and brackets just to eliminate that possibility.
DeeJaaY209
14
Sep 15, 2013 10:40 PM
SOFLSOL
Transmission & Drivetrain
Nov 20, 2012 06:37 PM
BB1LOViN
Jan 24, 2008 10:57 PM
oinkus
Apr 19, 2005 05:06 PM
1hotvtec
Oct 8, 2003 10:28 PM
