Could old/low tranny fluid cause this?
Old Apr 5, 2004 | 09:30 AM
JDM-Vic's Avatar
Default Could old/low tranny fluid cause this?
Could having low or old tranny fluid cause gears to stick even when you put it in neutral? For me my 2nd gear is almost impossible to get to slide in smoothly, and when I take it out of second gear and put it in neutral it wont go over to the 5th and reverse gears until I release the clutch. It will then make a banging sound and the shifter will move around, almost as iff it was still in 2nd gear and its poping out when I release the clutch. After that I can move it into 5th and reverse fine. It will also grind 3rd when shifting at high rpms(above 6500).
Could low or old tranny fluid cause this?
Old Apr 5, 2004 | 11:05 AM
JDM-Vic's Avatar
Default Re: Could old/low tranny fluid cause this? (JDM-Vic)
BUMP, with a pic of my car for help!
Old Apr 5, 2004 | 05:41 PM
JDM-Vic's Avatar
ttt
Old Apr 5, 2004 | 06:21 PM
BlueCrxNC's Avatar
Sounds to me like something internal is screwed up... Try a fluid change ASAP. Then if the issue is still there, you're going to need to crack the tranny open.
Old Apr 5, 2004 | 06:32 PM
boostn420's Avatar
You should try bleeding the clutch. It sounds like its not reaching full length.
Old Apr 6, 2004 | 12:23 AM
leadfoot78's Avatar
Default Re: Could old/low tranny fluid cause this? (boostn420)
I'd change the tranny fluid just since u should have done that a long time ago. Then id check the level of clutch fluid in the master cylinder, if its low fill it and check inside the car above the clutch pedal if its leaking fluid into the car, if it is, than u have a bad seal. This actually happens alot and its not expensive to fix, i have done it to my car. If its not leaking bleed the clutch.
Old Apr 6, 2004 | 07:28 AM
JDM-Vic's Avatar
How do I check the clutch fluid, and how do I change/bleed it? Anyone have a link to a step by step tutorial?
Old Apr 6, 2004 | 09:34 AM
showbiz's Avatar
Default Re: (JDM-Vic)
bleeding a hydraulic system is very basic , if you do a search you will find info
Old Apr 6, 2004 | 01:48 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Nice civic!
red5FWD
Jan 27, 2008 07:43 PM
bomber19
Oct 3, 2007 05:57 PM
GuCCi_GSR
May 13, 2005 09:41 PM
FLCivic
10
Apr 14, 2004 07:19 PM
stilzx61
Feb 14, 2004 01:28 AM
