I think I blew A Headgasket
Old Apr 5, 2004 | 09:18 AM
StupidSlowRSX's Avatar
Default I think I blew A Headgasket
Well, I was driving on a highway at about 90 mph, I came to a stop as I reached a light. Then as I started to accelerate ( somewhere around 60 mph ) the engine basically died off so I pulled into a gas station and sat for about 10 minutes then tried to start it again, it started. Idle fine to boot, then I gave it an inch of gas and it died again, It start back up after that. It cranks though, with no sounds of valves knocking..
So I think that when I started it again, and tried to give it gas, It just increased the hole. Thus causing my compression to be wack.
Anyone have other idea's?
Old Apr 5, 2004 | 09:25 AM
96-EJ6 B18C's Avatar
Default Re: I think I blew A Headgasket (StupidSlowCRX)
Is there water in the oil or vice versa???
Old Apr 5, 2004 | 09:49 AM
I Want An Si's Avatar
Any codes?
Old Apr 5, 2004 | 10:35 AM
EGNicoleAE86's Avatar
Default Re: I think I blew A Headgasket (I Want An Si)
It could be your distributor, i had to replace mine when i had that problem. Check the ECU and see if its throwing any codes.
Old Apr 5, 2004 | 01:15 PM
Default Re: I think I blew A Headgasket (EGNicoleAE86)
I checked the ECU right when I pulled over, No codes, non the less I reset it anyway, Still the same thing. I cant really tell if theres water in the oil. I just recently did an oil change. From what I can see I dont see any oil in the radiator. And the distributor was just replaced 3 months ago.
Old Apr 5, 2004 | 01:42 PM
RCautoworks's Avatar
If you split the head gasket between the cylinders oil will not be in the coolant and coolant will not be in the oil, you will loose compression in that cylinder. Which its unlikely your head gasket blew in 3 spots. Do a compression test to see though. When the car died, did it completely die or did it stumble.
Old Apr 5, 2004 | 02:08 PM
crxpilot's Avatar
sounds like the old main relay problem (car dies, wait a while, then it starts ok again). could be that or a bad igniter. i doubt a blown headgasket would cause your car to suddenly die. usually it causes lots of white smoke to pour from your exhaust first.
Old Apr 5, 2004 | 02:21 PM
tony's Avatar
personally i don't think its a headgasket problem i've been through 2 headgaskets adn it doesn't sound like you blew one. more like the main relay
Old Apr 5, 2004 | 02:27 PM
Default Re: I think I blew A Headgasket (tony)
Nah, about 5 months ago I had the main relay to, I resoildered it and its worked fine since. Besides, When my cabin warms up, it still doesnt start. I Just replaced the distributor, is it likly the ignitor is bad already? THe car just continiously cranks over..
Old Apr 5, 2004 | 03:05 PM
Charlie Moua's Avatar
Default Re: I think I blew A Headgasket (90blackcrx)
do compression test and let us know the resultes
Check for spark and fuel.
Old Apr 6, 2004 | 04:13 PM
Well, My compression was 180 on cylinders 2 3 and 4. and 165 on cylinder 1. However, Cylinder 4 has no spark, I just replaced the wires and the plugs are fine. Ill try the distributor tomorrow
Old Apr 7, 2004 | 01:22 PM
Default Re: (StupidSlowCRX)
Still no spark. ...
Old Apr 7, 2004 | 03:17 PM
onePOINTsix's Avatar
replace your rotor and cap on the dizzy then try again
Old Apr 8, 2004 | 11:39 AM
Default Re: (Sideout)
Well, I replaced the cap and Rotor today, and I made sure everything was installed correctly, and it almost starts, It sounds like its about to start but it just doesnt..
Old Apr 8, 2004 | 12:24 PM
up
Timing is fine..
Old Apr 8, 2004 | 04:13 PM
I feel really stupid and foolish, I didnt even check to hear the sound of the fuel pump. When I did I heard nothing. doh! Walbro 255 =] here i come
Old Apr 8, 2004 | 04:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Check for spark and fuel.</TD></TR></TABLE>
cough cough
Old Apr 8, 2004 | 04:56 PM
when you gonna make some zc valve covers? Powder coated :]
Old Apr 8, 2004 | 05:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX &raquo;</TD></TR><TR><TD CLASS="quote">when you gonna make some zc valve covers? Powder coated :]</TD></TR></TABLE>
I do all types of valve covers, you just need to send me them. Unless I can get a hold of some
Old Apr 8, 2004 | 06:08 PM
85mm LS VTEC's Avatar
Maybe you should check your ground wires.
Old Apr 8, 2004 | 06:22 PM
Default Re: I think I blew A Headgasket (85mm LS VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX &raquo;</TD></TR><TR><TD CLASS="quote">I feel really stupid and foolish, I didnt even check to hear the sound of the fuel pump. When I did I heard nothing. doh! Walbro 255 =] here i come</TD></TR></TABLE>
nah man... fuel pump
FUEL PUMP!!
hehe
fbjunkie53
Oct 5, 2008 04:34 PM
crazy_ham
Sep 11, 2007 04:48 PM
staticrex
Jun 25, 2004 05:02 PM
adam
Nov 13, 2001 06:45 PM
