crower stage 2? going to buy and looking for some input
Old Apr 5, 2004 | 06:09 AM
ensracer's Avatar
Default crower stage 2? going to buy and looking for some input
im looking to buy some crower sage 2 cams and i am just wondering if they will make a substancial diference. i am planning on ordering them this week and just looking for some input on people who have these. i have crower spring and retainer, port and polished head, head milled 40, type s pistons. will i notice a difference?
Old Apr 5, 2004 | 06:30 AM
Daboi630's Avatar
yes. take a look at the dyno pages in my sig.
i think someone hit 195ish with crower stage 2.
Old Apr 5, 2004 | 06:32 AM
94vtecmn's Avatar
Default Re: (Daboi630)
That is me, or at least I am one of them. 195.2, with no port or polish, no head milling, Type-S pistons .25 oversized. Basically it put down +20whp from the stock cams. I highly recommend them myself.
Old Apr 5, 2004 | 06:36 AM
ensracer's Avatar
wow nice... up to how high an rpm do these work at...i mean can you rev this higher or is it more power.
Old Apr 5, 2004 | 06:50 AM
Daboi630's Avatar
Default Re: (94vtecmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtecmn &raquo;</TD></TR><TR><TD CLASS="quote">That is me, or at least I am one of them. 195.2, with no port or polish, no head milling, Type-S pistons .25 oversized. Basically it put down +20whp from the stock cams. I highly recommend them myself.</TD></TR></TABLE>
i must need sleep because i don't see your dyno
Daboi630's Avatar
Default Re: (eduardo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eduardo &raquo;</TD></TR><TR><TD CLASS="quote">wow nice... up to how high an rpm do these work at...i mean can you rev this higher or is it more power.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrMike &raquo;</TD></TR><TR><TD CLASS="quote">
JDM 93 H22a
Crower Stage 2 cams, Manley springs and retainers
63mm throttlebody, stock intake manifold
Dented DC Sports Header, straight pipe, 2.25 piping to Apexi N1 NA muffler
Stock Head and bottom end, removed blance shafts
Fidanza flywheel, clutchmasters stage 4 clutch
dyno jet not sure what model
3rd gear pull
94vtecmn's Avatar
No, I don't have it posted on there, I could not get a postable copy at the time. However, I am getting an SMSP header, and I will be sure to get a postable copy for your link then.
Old Apr 5, 2004 | 06:52 AM
Daboi630's Avatar
whew. i thought i was going crazy for a sec.
Old Apr 5, 2004 | 06:53 AM
ensracer's Avatar
very nice numbers it produces power at higher than normal rpm's.... hopefully i can have these on by friday...thanks
Old Apr 5, 2004 | 06:54 AM
94vtecmn's Avatar
Don't forget to get it tuned, it will be way lean with those cams with the stock computer.
Old Apr 5, 2004 | 08:10 AM
donnjuan2point2's Avatar
Default Re: crower stage 2? going to buy and looking for some input (eduardo)
be careful cause crowers are known to break and give problems i recommend skunk 2 or ef-1
Old Apr 5, 2004 | 09:54 AM
PirateMcFred's Avatar
Default Re: crower stage 2? going to buy and looking for some input (donnjuan2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donnjuan2point2 &raquo;</TD></TR><TR><TD CLASS="quote">be careful cause crowers are known to break and give problems i recommend skunk 2 or ef-1 </TD></TR></TABLE>
I want Pics... If you don't have personal experience then Pipe down, otherwise name names of the people that have had problems... Flyrod has been running CrSt2 for 15,000 miles no problems, and has nice numbers too. If you want to know what he got then I would ask him. He'll tell if he wants to...
the Pirate
Old Apr 5, 2004 | 10:54 AM
NXLude's Avatar
first, crowers dont break, a couple sets broke years ago and everyone thinks they are bad, not true. They have made cams since skunk2 was pooping yellow.....
Second, you need to do sonme research before you do this, milling your head 40 and putting those cams in with type s pistons is going to do nothing but break things......
Third SEARCH!!!! there is tons of freaking info on here, if you want answers do some research and then come post a question...
Ls InTeGrA RaCeR
Oct 22, 2005 10:54 AM
connvict
Jul 4, 2004 11:59 PM
ViZ
Jun 6, 2003 11:11 AM
96SR-V
Jul 23, 2002 08:31 AM
