Car want to die at 75-80mph?
I was driving to an SCCA event last night and on my way down the car started to act like it wasnt getting enough fuel but i would either throttle it more and it would pick up again but then act the same and i would have to keep doing it. Unless i put it in 4th and crusied at 4500rpm. what do you think it could be!? Fuel pump? O2 sensor? My set-up is below! Help!
I had a similar problem, dont know if it'll help
I had a ground loose on my thermostat and when i would get up to about 70 it would freak out, I dont know why it would do that at speed?
so you might take a look at it, or any other wireing that would move, thats what I did, I had my car idle and then I went under the hood and wiggled all the wires until I found it.
good luck
good luck
justbriaN
12
Mar 2, 2011 02:25 PM
_Bug_
17
Feb 8, 2007 10:31 AM
Dancing is Forbidden
12
Nov 21, 2005 08:00 PM
