P30 ECU?
Old Apr 4, 2004 | 05:08 PM
drvfast's Avatar
Default P30 ECU?
Is anyone running a p30 ecu with an xsi swap in there crx? If so does it run better than using the orginal pr3 ecu. Thanks
Old Apr 4, 2004 | 05:53 PM
drvfast's Avatar
Default Re: P30 ECU? (drvfast)
bump
Old Apr 4, 2004 | 06:48 PM
drvfast's Avatar
anyone
Old Apr 4, 2004 | 07:34 PM
PHiZ's Avatar
It will run as an OBD1 ecu, as long as everything is wired appropriatly. And all the sensors are provided for (OBD0 and OBD1 dizzys are not compatible.)
-PHiZ
Also the USDM P30 may look for some emissions sensors that the PR3 definitly doesn't.
regime's Avatar
p30 is a obd1 ecu. an xsi is obd0.
you can switch to obd1 (many ppl do)
but then you can just run a p28 and have it tuned to what ever the hell you want out of it
p30 would just be a lil harder to find and probably a lil more money i would think
Old Apr 4, 2004 | 08:23 PM
drvfast's Avatar
Default Re: P30 ECU? (PHiZ)
thanks guys everything is wired correctly to run the p30.
Old Apr 4, 2004 | 09:18 PM
VAAJ's Avatar
My p30 seems to run leaner then my old Pr3 ecu.
prestidge81
Jul 18, 2007 12:47 AM
hondateg10
Mar 25, 2007 03:50 PM
FOMULA91
Jul 18, 2005 01:31 AM
sullenht
Sep 28, 2004 01:00 PM
Superhatch
Jan 29, 2003 06:30 AM
