Koni Adjustables (internal) - Are they supposed to rebound?
Old Apr 4, 2004 | 04:29 PM
WeaponR
Guest
Posts: n/a
Default Koni Adjustables (internal) - Are they supposed to rebound?
I just bought some new Koni Internally adjustable shocks for my car - One of them rebounds, the other does so at a slower rate and does not rebound fully. It still has considerable resistance when I push down on it, and the guy I bought them from said that this is normal since they are not nitrogen based. I am not convinced, since one does fully rebound, and the other only rebounds half way and is much slower.
Any comments?
Old Apr 4, 2004 | 05:33 PM
Tweakmeister's Avatar
Default Re: Koni Adjustables (internal) - Are they supposed to rebound? (WeaponR)
how are they adjusted?
if it's close to firm, then it will VERY slowly rebound.
go ahead and push it in all the way, then turn it (you'll feel it click/engage) and make sure they are matching adjustment-wise.
Old Apr 6, 2004 | 10:32 PM
WeaponR
Guest
Posts: n/a
bump
Old Apr 7, 2004 | 03:18 AM
.RJ's Avatar
.RJ
You should lick them.
That will do as much good as pushing on them off the car.
Old Apr 7, 2004 | 06:02 AM
Erik95LS's Avatar
Default Re: Koni Adjustables (.RJ)
I'll bet Konis are tasty too.
did you check to see if they are set at the same level of adjustment?
Old Apr 7, 2004 | 11:09 AM
Default Re: Koni Adjustables (Erik95LS)
I told you what to do, and you don't even acknowledge my post?
Old Apr 7, 2004 | 11:13 AM
Erik95LS's Avatar
Default Re: Koni Adjustables (Tweakmeister)
yeah I was wondering about that
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">I told you what to do, and you don't even acknowledge my post?</TD></TR></TABLE>
And ... the Road Race Mod should know better than post such garbage!
Old Apr 7, 2004 | 08:05 PM
greenf1's Avatar
That's a disadvantage of twintube gas shocks. Each shock is not guaranteed to have identical rebound/compression properties due to its design. Monotube gas shocks are more likely to have consistent movements.
Old Apr 7, 2004 | 10:03 PM
WeaponR
Guest
Posts: n/a
Sorry for not acknowledging your post earlier. Both shocks are brand new. One, I can adjust easily. The other one (the one that won't rebound), I cannot seem to adjust. It seems "seized" in one setting.
Old Apr 8, 2004 | 06:44 AM
greenf1's Avatar
Default Re: Koni Adjustables (WeaponR)
Oh by the way, it's suppose to rebound all the way through. If it doesn't, its defective and send it back to Koni. The ones I have both rebound all the way but not at the same identical rate.
Old Apr 8, 2004 | 07:07 AM
pcorad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WeaponR &raquo;</TD></TR><TR><TD CLASS="quote"> It seems "seized" in one setting.</TD></TR></TABLE>
Send it back. I had an "adjuster" seize and sent it back. A friend had some koni issues too, and sent them back.
92civeg
Suspension & Brakes
10
Apr 27, 2008 04:11 PM
goodtrouble
Sep 5, 2007 08:01 PM
JDM RHD eg6
Suspension & Brakes
14
Feb 1, 2005 10:21 AM
AcuraEL
Feb 27, 2003 04:55 AM
96 SOHC VTEC
20
Jan 8, 2002 11:40 PM
