The Little SOHC that Could.....Finally Dyno'd my Z6 at 12psi!!!!
Old Apr 4, 2004 | 01:03 PM
ladysman's Avatar
Default The Little SOHC that Could.....Finally Dyno'd my Z6 at 12psi!!!! 4/12 Videos Added!!
Well, I finally made it to the dyno before the motor gets put in. They was a dyno day at FC Customs in Springfield, IL yesterday and I decided to take advantage of it. 3 runs for $45, not bad.
Videos added!!!!
Broadband (14mb with me screaming "Holy Shitballs, 262!")
56k Condensed Version
Some of you have seen my post on my car and hondata setups. They can be viewed here.
Turbo Setup
Hondata
So everyone knows, this is a STOCK BLOCK!!
I first looked at the dyno screen and saw the 217 number and was like, not bad. The gentleman in the drivers seat doing the pull says to me "Ah, that's the torque number". I about lost my McDonald's at that point.
The first run netted 262whp and 217wtq. All of this on 12.3xx psi. I couldn't believe it!! The next run I decided to fix the horrible A/F line that was occurring. I fixed it a little but I was going to need more than 2 runs to get a straight line. I am guessing about 6-7 more pulls would have done it. I didn't really see a need since the new setup was going in and I didn't want to push my luck.
I then got greedy. I upped the AVCR ~2-2.5 psi. We only got to about 5800 rpm when the CEL popped on solid and the car stopped. I thought she blew. Turns out it didn't. Car was perfectly fine. We tried it again with the same result. The only thing I can think of is the stock map sensor doesn't like that much boost. I didn't feel the like retuning everything with the 3 bar sensor so I just left the stock sensor in (I know, I know but I have been running it this way for a year just richening the latter part of the boost map to compensate for it. Not the best solution but it works....................to a certain point I now think).
Anyway, the last run would have been somewhere around 290-300 is my guess. Right at about 1 bar of boost. Not bad for a little SOHC?!
Dyno from yesterday is here.
I have vids of this but I need to find a place to host them first. 1 is on a digital camera the rest are on my MiniDV camera. Yesterday got me syked about getting the car done now!!! Enjoy.
I wanted to add this was all tuned by myself with the advice of some Honda-Tech'ers Like I said, the car's AF could have been improved to get a nice line but the changes I made I could tell made a difference. By they way, the A/F up top was a conservative 11.8:1.
Brad
Edit: Added Pics
Here I am (Hooded Sweatshirt) telling him to put the strap on the Jimfab Traction bar. I thought you would like to see my better half.
Modified by ladysman at 4:17 PM 4/4/2004
Modified by ladysman at 4:40 PM 4/4/2004
Modified by ladysman at 7:36 PM 4/4/2004
Modified by ladysman at 5:17 PM 4/12/2004
Modified by ladysman at 5:18 PM 4/12/2004
Modified by ladysman at 5:23 PM 4/12/2004
Old Apr 4, 2004 | 01:09 PM
Sonny's Avatar
Default Re: The Little SOHC that Could.....Finally Dyno'd my Z6 at 12psi!!!! (ladysman)
Badass!
Sonny
booscivic's Avatar
Awsome numbers!!!!
Pfieff's Avatar
very impressive #'s
Old Apr 4, 2004 | 01:14 PM
T-RO's Avatar
Damn nice job there.
Old Apr 4, 2004 | 01:28 PM
nigel's Avatar
sweet car and numbers dood!
Old Apr 4, 2004 | 01:56 PM
ELSpool's Avatar
whoa! thats crazy numbers!!
Old Apr 4, 2004 | 02:00 PM
hybrid93SIvic's Avatar
Default Re: (ELSpool)
****** sweet!
Old Apr 4, 2004 | 02:35 PM
hYbRiD EeEkAy's Avatar
is this on a stock block or built?
Old Apr 4, 2004 | 02:36 PM
boosted-delslow's Avatar
Default Re: The Little SOHC that Could.....Finally Dyno'd my Z6 at 12psi!!!! (KwikEG)
Nice numbers!!!
Old Apr 4, 2004 | 02:47 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KwikEG &raquo;</TD></TR><TR><TD CLASS="quote">is this on a stock block or built?</TD></TR></TABLE>
Completely Stock. Built setup going in shortly!!
Old Apr 4, 2004 | 02:49 PM
ExVtec's Avatar
impressed. for #'s. Clean ride also. Keep up the good work.
Old Apr 4, 2004 | 02:51 PM
D-Man's Avatar
Congrats on the HP numbers My stock MAP use to do the same thing once it passed 10psi or so.
Old Apr 4, 2004 | 03:01 PM
1point5CRX's Avatar
Default Re: The Little SOHC that Could.....Finally Dyno'd my Z6 at 12psi!!!! (D-Man)
i love it sohc
Old Apr 4, 2004 | 03:27 PM
gitwidit's Avatar
Default Re: The Little SOHC that Could.....Finally Dyno'd my Z6 at 12psi!!!! (1point5CRX)
Nice work Brad your next setup is gonna be shizwheat
Old Apr 4, 2004 | 03:28 PM
maddog20's Avatar
Damn! enough said!
Old Apr 4, 2004 | 03:44 PM
teal EJ1's Avatar
Default Re: (maddog20)
amazing ...how long have you been driving around on 12lbs?
Old Apr 4, 2004 | 03:49 PM
ladysman's Avatar
Default Re: (teal EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">amazing ...how long have you been driving around on 12lbs?</TD></TR></TABLE>
About 1 year.............................~2500 miles I don't get the car out that much. It sat for about 3 months and I never touched it. It started right up at the beginning of March. I think it was pissed I didn't use it.
Old Apr 4, 2004 | 03:56 PM
AzCivic1.6's Avatar
what are other people pulling with similiar setups on dseries blocks? this is alot for 12psi isnt it?
Old Apr 4, 2004 | 04:04 PM
5thgencivic's Avatar
Default Re: (ladysman)
Sick numbers! And on a stock block too. You made more than I did at 12psi..
Old Apr 4, 2004 | 04:08 PM
turbo_ef9's Avatar
Default Re: (5thgencivic)
woah... i wonder how much i was pushing at 12psi.. i was thinking i would dpull 225whp.. but thats crazy though.. good numbers.!
Old Apr 4, 2004 | 04:35 PM
Mikey361's Avatar
Default Re: (eli_vang)
thats amazing guy kinda makes me wanna do the z6 swap
over the h22 or b18c, whats your turbo set-up? good #'s
bro ,and good luck with your new motor when you get it.
Old Apr 4, 2004 | 04:37 PM
ladysman's Avatar
Default Re: (mle_92cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mle_92cx &raquo;</TD></TR><TR><TD CLASS="quote">thats amazing guy kinda makes me wanna do the z6 swap
bro ,and good luck with your new motor when you get it.</TD></TR></TABLE>
Click on the "Turbo Setup" link in my post.
Old Apr 4, 2004 | 04:50 PM
lgcubana's Avatar
I believe that the stock MAP sensor can only read up to approximately 15 psi. I had a secondary sensor installed that my E-Manage reads. I'm a Fluidyne radiator away from trying 15 --&gt; 16 psi. Your posted numbers R a good incentive for me to start saving for the dyno time.
Old Apr 4, 2004 | 05:04 PM
danl's Avatar
Banned
Dude, that is just awsome!
