FS: Misc Integra / Civic parts sitting in the garage. Stock and aftermarket.
Old Apr 4, 2004 | 11:24 AM
Boofster's Avatar
Default FS: Misc Integra / Civic parts sitting in the garage. Stock and aftermarket.
Ok, need to get rid of all this junk that's been piling up:
98 Integra GS:
* B18B1 complete engine swap w/90K miles
* Radiator and cooler fans
* Shocks
* Springs
* Brake rotors (all 4)
* Brake lines
* Exhaust
* Catalytic converter
* CD player w/code
* Fuel filter
* Fuel pump
* Automatic antenna assembly
* Rear window wiper w/motor
* Airbox assembly
* Sway bar
* Rear camber links
* Side skirts
96 Integra GSR:
* Differential
* Inner harness
* Flywheel
* Clutch + disk
* Clutch slave cylinder
* Intake manifold
* Throttle body (60mm, TPS broken, MAP ok)
* Fuel Rail
* 2 Oil pans (few bumps)
* Down pipe
* Header w/heat shield
* Injectors
* Mounts (all 3)
* Rear mount bracket
* P72 ECU (OBD2)
95 Civic EX:
* Optional center console
* ABS Unit
* Grey casette deck
* Sims Clear red distributor cap
* Shocks
* Springs
* Exhaust
* Airbox assembly
* Tail lights (sedan)
* Red/White tail lights (sedan)
* Clear corners front (sedan)
* Rear camber links
Other:
* ITR AEM Cold Air Intake Kit (3" pipe) w/all parts
AEM Part# 21-412 Blue
used ~ 4 months, perfect condition, no scratches.
Fits LS and ITR manifolds.
* AEM bypass valve
Part # 20-401s
* Synapse Engineering Missing Link
The ML-001B Has been Engineered for the Following Turbocharged Vehicles:
1994 – 2001 Acura Integra B18 series engine
1992 – 2002 Honda Civic Z16/B16/D16 series engine
1994 – 2002 Honda Accord
1997 – 2002 Honda Prelude H22 series engine
1999 – 2002 Honda S2000
* 5Zigen Fireball exhaust muffler
Came from the catback. Small in the axle section.
* Neuspeed rear upper tie bar.
Small bend on one side.
* Integra gauge bezel with extra gauge slots
* STR Red cam seal
* 1 Koni Sport (yellow) front shock 8041-1152
* Blitz DD Blow-off valve (brand new)
* 2 ingalls front camber adjusters (for one wheel only)
Modified by Boofster at 9:51 PM 4/4/2004
Modified by Boofster at 9:57 PM 4/4/2004
Modified by Boofster at 10:14 PM 4/4/2004
Modified by Boofster at 10:54 PM 4/4/2004
Modified by Boofster at 12:25 AM 4/5/2004
Old Apr 4, 2004 | 11:33 AM
JDM EJ1 95's Avatar
what exactly is the optionial center console for the EJ1? is it like the JDM audio console?
Old Apr 4, 2004 | 11:53 AM
TRAY's Avatar
Default Re: (JDM EJ1 95)
how much for the antenna shipped to cali? its the whole assemble right with the motor and all? pm me please....
Old Apr 4, 2004 | 05:52 PM
Boofster's Avatar
Optional console is for the EG. Uses up that space where your cup holders are.
https://honda-tech.com/zerothread?id=687097
Old Apr 4, 2004 | 06:01 PM
RiceBurninVTEC
Guest
Posts: n/a
interested in the integra gauge bezel. got a pic?
Old Apr 4, 2004 | 08:56 PM
Boofster's Avatar
Default Re: (RiceBurninVTEC)
Updated list a bit.
Here's the bezel:
made by these guys: http://www.poliauto.com
Brand new. I couldn't use it cuz my a/c bezel
Modified by Boofster at 11:02 PM 4/4/2004
Old Apr 4, 2004 | 09:20 PM
integraguy17's Avatar
Default Re: (Boofster)
hey how mcuh yu want for the engine b18 swap and shipped to PA 19111?
Old Apr 4, 2004 | 10:01 PM
Boofster's Avatar
Default Re: (integraguy17)
I want $1500 for the engine and I think it's $200 to crate and ship.
It's block, tranny, axles, ecu, ps, a/c, alt, mounts.
Old Apr 4, 2004 | 11:46 PM
TRAY's Avatar
Default Re: (TrayDay2K1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrayDay2K1 &raquo;</TD></TR><TR><TD CLASS="quote">how much for the antenna shipped to cali? its the whole assemble right with the motor and all? pm me please....</TD></TR></TABLE>
Old Apr 6, 2004 | 06:23 PM
Boofster's Avatar
pm answered
Old Apr 6, 2004 | 06:34 PM
nick.na's Avatar
whats your asking price for the cat? is it gutted? thanks
Old Apr 8, 2004 | 08:57 PM
Boofster's Avatar
Default Re: (075nick)
which cat are you interested in? civic or teg? they're both stock. $50 bux shipped.
92integraVTECgsr
May 17, 2010 07:32 PM
D-booster
Mar 30, 2010 11:00 AM
regdog77
Jun 15, 2007 10:05 AM
