approaching 120K...what is the recomended service???
i dont have my manual infront of me but i have just started noticing my maintence required light start to flash and i know it will be solid soon enough. Im guessing its for lame stuff but i didnt know if it recomended anything major. Anyone know off hand???
120K on a GSR?
w/ regular maintenance and not beating on it all the time you can keep it running to 200K. I say repeat the 60K maintenance - plugs, wires, oil change, tranny fluid change, adjust valves, set timing, dist cap/rotor
if u didn't do the 90k service then you should do that
but if u did already...then you got alot more miles
maybe blue print your engine, and carbon clean all the deposits
flush all the fluids, new clutch, the ez things, all the metal parts
are still strong but the lil stuff might be worn...ringsss valves ect....
oh yeah i said that, cause im approaching 100k and its scary 50+ miles a day man
for skool
[Modified by bommiE, 2:28 PM 10/25/2001]
for skool
50+...please, i get about a month between oil changes. I drive way to damn much and i hate every minute of it. All previous servious has been done from the beginning up to the 90K service. Havnt adjusted the vavles in a long time which i should probably do and most likely will.
at one point i only got 3 weeks a oil change... haha lucky for my car i dont do that anymore... i say just get the basic tune up.. wires, plugs, cap...etc
If you havent already changed these at 90,000: water pump, oil pump, wires, spark plugs, distributor cap, tranny fluid, brake fluid, clutch fluid. Good luck
froger
Jun 3, 2005 08:58 PM
