ep and element hybrid???
yes you can. P7 auto has done it. a note of warning though, you will not be able to rev it like you can a crVTEC hybrid. the reason being that the K24 has too much piston travel to achieve those high RPMs.
the k24a1 which is the engine in question can be matched up to the k20a3, but is the identical head. if you are doing this to do a crvtec like setup you need to get an k20a2 or k20a to see the benefits. I would imagine with the k20a3 ecu reflashed it would be a nice setup, but don't go to the troubies of putting the a3 head on it
92hatchattack
Engine Machining & Assembly
Sep 1, 2006 02:59 PM
