D16 Rod Bolts, are they needed?
Old Apr 3, 2004 | 05:54 PM
onePOINTsix's Avatar
Default D16 Rod Bolts, are they needed?
I'm started my A6 buildup (read sig) and i was wondering if i should get new rod bolts (ARP). If so do i need the 8mm or 9mm bolts? I dont really think i need them, i'll probally just get OEM new bolts.
BTW it is revving to 7500rpm, nothing crazy
Old Apr 3, 2004 | 07:29 PM
SleepyHF's Avatar
Default Re: D16 Rod Bolts, are they needed? (Sideout)
How much was your total cost on building that a6 beast??
Old Apr 9, 2004 | 11:53 AM
Default Re: D16 Rod Bolts, are they needed? (SleepyHF)
i'm not finished with it yet. I got the block and head free (both from A6 with 130k on it), the head will have Delta 272 cam ($80), JG Spring w/ stock retainers ($120), and a mild port job i'm working on. The block will have P29 pistons ($210 with rings), shotpeened and balanced rods ($60), and i'm debating if $105 for ARP head studs is worth it. I might go with new stock ones ($56) because i'm only revving to 8000rpm. Oh yeah and a Y8 head gasket ($35).
So grand total is somewhere around $550-$600 for the whold build. If I hit 140hp i'll be happy, the motor is being built for endrance not max power.
Old Apr 9, 2004 | 11:56 AM
SleepyHF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">i'm not finished with it yet. I got the block and head free (both from A6 with 130k on it), the head will have Delta 272 cam ($80), JG Spring w/ stock retainers ($120), and a mild port job i'm working on. The block will have P29 pistons ($210 with rings), shotpeened and balanced rods ($60), and i'm debating if $105 for ARP head studs is worth it. I might go with new stock ones ($56) because i'm only revving to 8000rpm. Oh yeah and a Y8 head gasket ($35).
So grand total is somewhere around $550-$600 for the whold build. If I hit 140hp i'll be happy, the motor is being built for endrance not max power.</TD></TR></TABLE>
d series are tight, and from the facts pretty cheap to build up
Old Apr 9, 2004 | 02:23 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
get the head AND the rod bolts. i believe it is a nessesary precaution. i did.
stan
noender
Sep 24, 2010 12:39 PM
hybrid2007
May 19, 2007 12:53 PM
akura404
Mar 3, 2006 02:12 PM
DEMNTD1
Nov 2, 2004 04:12 AM
ls95hatch
15
Apr 10, 2004 06:58 PM
