SRS lite - what to do!?
Old Apr 3, 2004 | 04:58 PM
CYM19z's Avatar
Default SRS lite - what to do!?
SRS lite-- u take off tha OME steering wheel.. throw on a sparco unit.. now yoru srs lite is ON.... what do to to make it go off? - im laready throwin a code for not having a Cat....
Old Apr 3, 2004 | 06:04 PM
..::91TEG-G2::..'s Avatar
Default Re: SRS lite - what to do!? (CYM19z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CYM19z &raquo;</TD></TR><TR><TD CLASS="quote">SRS lite-- u take off tha OME steering wheel.. throw on a sparco unit.. now yoru srs lite is ON.... what do to to make it go off? - im laready throwin a code for not having a Cat....</TD></TR></TABLE>
what car is this for? and u should ask in the tech forum.. not here in audio, they'd help you better with the SRS light then this forum probably would...
Old Apr 4, 2004 | 07:00 AM
rjr162's Avatar
Default Re: SRS lite - what to do!? (..::91TEG-G2::..)
you can put tape over the light. Really I don't think there's much you can do other than trick the SRS unit into thinking the airbag is still there. I'm sure a resistor of the correct resistance would accomplish this, but I'm not sure of what value or if infact it would work.
Oh, and don't try to ohm out your old airbag to find what value the resistance is, you could accidentally blow the bag.
Old Apr 4, 2004 | 07:05 AM
ASHY-ELBOW's Avatar
Default Re: SRS lite - what to do!? (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">you can put tape over the light. Really I don't think there's much you can do other than trick the SRS unit into thinking the airbag is still there. I'm sure a resistor of the correct resistance would accomplish this, but I'm not sure of what value or if infact it would work.
Oh, and don't try to ohm out your old airbag to find what value the resistance is, you could accidentally blow the bag.</TD></TR></TABLE>
yeah what he said, u can try and take a meter to the bag and see what res it is and then use the correct resistor to make the light go out, i in the past done one before where i used a variable resistor and the light went out , but on my car i just took the bulb out
Old Apr 4, 2004 | 04:43 PM
Auex's Avatar
Remove the bulb from the instrument cluster?
Old Apr 4, 2004 | 06:01 PM
ASHY-ELBOW's Avatar
Default Re: SRS lite - what to do!? (Auex)
yupp, or just unplug teh yellow plug on the cluster
Old Apr 10, 2004 | 11:36 PM
CYM19z's Avatar
Default Re: SRS lite - what to do!? (ASHY-ELBOW)
yeah i guess that would work too...
anotehr ques.. if u go abck to stock for State testing reasons.. is tha airbag gonna be messed up..? as it tha ECU is goin to think it went off?
Old Apr 12, 2004 | 09:27 AM
spark plugs.
Guest
Posts: n/a
in CT, do they do a diagnostic check (with a scan-tool) for inspections? otherwise, they won't even know.
Old Apr 12, 2004 | 10:28 AM
rjr162's Avatar
Default Re: SRS lite - what to do!? (troublecodes)
The airbag won't mess with emmisions of course, but I don't know what your state regulations are with the missing airbag. They may say since the car came with one it must have one to be street legal and pass inspection. Otherwise, if they dont' require it, make sure you call your insurance company and tell them the airbag is removed. You'll loose your airbag discount, but they won't be able to slap you with insurance fraud if you get into an accident and they find out the airbag was removed.
lamboextreme
10
Sep 24, 2007 06:09 PM
92ehatch
Jul 30, 2006 05:57 PM
eLuder93
Oct 1, 2004 10:48 AM
WalkingKenshin
Apr 2, 2004 07:47 AM
Marauder
Apr 11, 2003 03:26 PM
