First time at track with new car, Questions
Old Apr 3, 2004 | 03:57 PM
fygtbug's Avatar
Default First time at track with new car, Questions
So I got the car to the tack today finally, only made 2 passes, really only wanted to see how the car felt. Anyway, when launching and under power ( boost hits ) cars pulls like a mother to the left, as in really pulls to the left had to shut it down to save from getting into the wall...Man I was scared.... So anyway, anyone want to give me tips on setting up the suspension, and so on....
Oh yeah running "ahem" VR6T making close to 500whp with 27x10x15 slicks, Quaife LSD, suspention is the Bilstein PSS9
Old Apr 3, 2004 | 03:59 PM
tony1's Avatar
Default Re: First time at track with new car, Questions (fygtbug)
Double check your tires pressures, they have to be even! One being off a little could cause that. There's really no trick to suspension as far as making it go straight out of the hole. It also helps if you line up straight, though i'm not saying that you weren't, just stating that.
Old Apr 3, 2004 | 04:18 PM
fygtbug's Avatar
Default Re: First time at track with new car, Questions (tony1)
both tires were 10psi, M&H slicks, it's not just the launch it was all the way down the track, car just wanted to pull to the left all the way, first run, I didnt warm up the tires just wanted to see how it went down the track, second time I warmed them up, first time saw alot of wheel spin, duh ofcourse LOl, but still pulled left, just not at as bad, second time, it was a real fight to hold the car straight, thats why I shut it down by the 1/8th, I have to admit I was pretty scared LOL.....
This is the second run, you can see how far it veers nearly in the blue before the 60'
Right click and save as
http://bolsen.homeip.net/images/gld/darren2.MPG
Old Apr 3, 2004 | 04:27 PM
b16ahybrid's Avatar
Do you have a lsd
Old Apr 3, 2004 | 04:32 PM
fygtbug's Avatar
Default Re: First time at track with new car, Questions (b16ahybrid)
yeah quaife
Old Apr 3, 2004 | 07:38 PM
Suprdave's Avatar
Alignment? Double Check it...
Old Apr 3, 2004 | 09:39 PM
D-Man's Avatar
Default Re: First time at track with new car, Questions (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Alignment? Double Check it...</TD></TR></TABLE>
Yes,I agree but make sure you get a 4-Wheel alignment,not just the front.If the alignment checks out ok,I would check/change/beef up all the motor/tranny mounts to play it safe.
btw..maybe you could put it on a dyno and see how the car reacts.
Old Apr 4, 2004 | 04:44 AM
speedworks's Avatar
Default Re: First time at track with new car, Questions (D-Man)
does your car have equal length axles and a half shaft like a honda or one long and one short axle. one long and one short will do the same thing with a lot of power.
Old Apr 4, 2004 | 08:22 AM
RacerStev's Avatar
DO you have large spacers between the hub and the wheel?
Old Apr 4, 2004 | 08:44 AM
fygtbug's Avatar
Default Re: First time at track with new car, Questions (RacerStev)
Shafts are short on the drivers side, long on the passenger, no half shafts for us VW guys ...
Wheels are made by Bogart, so the only spacer in there is for brake clearance
Old Apr 4, 2004 | 10:46 AM
RacerStev's Avatar
My Neon has the same setup as you do, long and a short. Last year I was also
experianceing the same thing, real hard pull to the left.
I had 1" spacers between the wheel and the hub, I assumed this was causeing
the pull. So I moved the strut in to clear the wheel w/o the spacer. At the same
time I installed camber plates and replaced the stock rubber control arm bushings.
One of the 3 mods cured the problem, she pulls straight as a string now.
Hope this helps!
Gofastturnleft
Jul 26, 2010 06:40 PM
Urugly
Jun 12, 2008 04:02 AM
snake01
May 18, 2003 09:08 PM
PM-Performance
Oct 21, 2002 10:31 AM
uncleben
19
Aug 24, 2002 09:25 PM
